In the ADL documentation it´s mentioned, that if you want to write alot of data via alot of calls to the flash-memory, one should “make a pause” every know and then
Most likely it isn´t going to be an exact amount like 1849 calls, but how much can be done without using timers?
2? 3? 4? 10? 100? 1000?
The watchdog timer resets the module if the module runs anything continuously for more than 5 seconds. If you want to do a lot of flash writing, it may be simplest to turn it off before writing and turn it on later.
