I’m working with an HL7900 module and trying to download the CEP (ephemeris prediction) file to speed up GNSS TTFF, using the AT%IGNSSCEP command.
Module info (ATI9):
- Firmware: SWI1350L.4.8.22060521.01 (Release 4.1, build 2026/03/31)
- Chipset Vendor Stack: BF_CORE_02_02_00_00_60521
- GNSS: ALT1350_02_02_00_00_55341_IGNSS (build Dec_31_2025)
Issue:
Running AT%IGNSSCEP="DLD" alone returns a plain ERROR (even with AT+CMEE=2 enabled, no +CME ERROR detail is returned — suggesting a parsing/syntax rejection rather than a runtime failure).
Network attach and PDP context are both confirmed active:
AT+CGATT?
+CGATT: 1
AT+CGACT?
+CGACT: 1,1
Querying the command’s expected syntax gives:
AT%IGNSSCEP=?
%IGNSSCEP: ("DLD","CLR","STAT","ERASE","PRECALC"),(URL,username,password)
So it’s clear the command expects a URL, username, and password as parameters — but I can’t find any documentation specifying what these should be, or whether they need to be requested from Sierra Wireless/Semtech.
Related known issue: KAVALAN-1043 (documented as fixed in the Release 4 Customer Release Notes, iGNSS domain) references this exact CEP download failure, and notes that “the CEP file can be successfully downloaded on a laptop using the provided URL, username, and password” — implying these credentials exist and are provided somewhere, but I haven’t been able to locate them.
Question: Could someone confirm:
- The correct default CEP server URL for HL7900 modules?
- Whether username/password credentials are required, and if so, how to obtain them (per-customer account, distributor-provided, or a shared default)?
- The exact syntax for AT%IGNSSCEP=“DLD” with these parameters?
Thanks in advance for any pointers.
