I’ve testet with the original Sierra Wireless HL78 dev kit.
I tried changing the baud rate but I get the following error:
AT+IPR?
+CME ERROR: 4
AT+IPR=?
+CME ERROR: 4
AT+IPR=38400
+CME ERROR: 4
What could be wrong?
i don’t see problem:
ati3
HL7812.5.4.10.0
at+ipr?
+IPR: 115200
at+ipr=?
+IPR: (1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400, 460800, 921600, 3000000)
Strange - here is my log:
are you using UART0?
I’m using the HL78 dev kit and have connected it to “MAIN USB”.
I see 4 serial communication ports in Device Manager:
Probably AT, AT/PPP, NMEA and MSE (Modem to USE).
AT commands are possible via COM7 and COM12 (probably AT and AT/PPP).
COM12:
COM7:
can you try with the UART1 port?
Are you using uart or usb?
Does problem only happen in windows?
Did you try linux?
So far I have only tested on Windows (10).
Today I don’t have a chance to test it with a Linux system (maybe in the next few days).
Thanks all for your help and support. I now did fixed the problem:
Although all AT commands work fine, if closed with CR only, the header information must be closed by CR_LF
Now everything work as expected.
//--- add http header ---
sprintf( Usart3_TxBuffer, "Accept: text/plain\r\n" );
SendCmdToGsmModul( Usart3_TxBuffer );
sprintf( Usart3_TxBuffer, "Content-Type: application/x-www-form-urlencoded\r\n" );
sprintf( Usart3_TxBuffer, "Content-Length: %d\r\n", BytesToSent );
strcpy( Usart3_TxBuffer, "--EOF--Pattern--" );
SendDataToGsmModul( Usart3_TxBuffer, 16 );
AnswerReceived = WaitForModemAnswerOk( RX_ACK_TIME );
