HL7812 IoT project
Hi sebastien.trocherie,
  1. HL7812 support Power Saving Mode, which is defined on 3GPP 27.007
  2. HL device provides connectivity with sim card inserted.
    AT command can be used to make a connection to MQTT broker. You can refer this topic
    TCP/SSL connection failure (HL7802)
  3. I think MCU is needed for sensor data. You can find example on this page. Note that AirVantage acts as a broker in this case:
    Getting started with HL module on RaspberryPI or Linux-based system - av - Sierra Wireless
  4. I’m not familiar with PCB design. You could see the document here:
    AirPrime - HL78xx - Customer Process Guidelines
