I have an embedded linux system running 2.6.24 kernel. When I try and compile the GobiSerial drivers for the MC7304 modem I get the following errors. Can someone please advise? It appears this driver was written to handle legacy kernels.
CC drivers/usb/serial/GobiSerial.o
drivers/usb/serial/GobiSerial.c:218:2: warning: #warning “Using legacy method of locking disc_mutex”
drivers/usb/serial/GobiSerial.c: In function ‘Gobi_lock_disc_mutex’:
drivers/usb/serial/GobiSerial.c:220: error: ‘struct usb_serial’ has no member named ‘disc_mutex’
drivers/usb/serial/GobiSerial.c:221: error: ‘struct usb_serial’ has no member named ‘disc_mutex’
drivers/usb/serial/GobiSerial.c: In function ‘Gobi_unlock_disc_mutex’:
drivers/usb/serial/GobiSerial.c:224: error: ‘struct usb_serial’ has no member named ‘disc_mutex’
drivers/usb/serial/GobiSerial.c: In function ‘Gobi_dtr_rts’:
drivers/usb/serial/GobiSerial.c:383: error: ‘struct usb_serial’ has no member named ‘disconnected’
drivers/usb/serial/GobiSerial.c: At top level:
drivers/usb/serial/GobiSerial.c:503: error: unknown field ‘dtr_rts’ specified in initializer
drivers/usb/serial/GobiSerial.c:503: warning: initialization from incompatible pointer type
drivers/usb/serial/GobiSerial.c:505: error: unknown field ‘release’ specified in initializer
drivers/usb/serial/GobiSerial.c:505: warning: initialization from incompatible pointer type
drivers/usb/serial/GobiSerial.c: In function ‘flush_and_resubmit_read_urb’:
drivers/usb/serial/GobiSerial.c:887: error: implicit declaration of function ‘tty_port_tty_get’
drivers/usb/serial/GobiSerial.c:887: error: ‘struct usb_serial_port’ has no member named ‘port’
drivers/usb/serial/GobiSerial.c:887: warning: initialization makes pointer from integer without a cast
drivers/usb/serial/GobiSerial.c:893: error: implicit declaration of function ‘tty_kref_put’
drivers/usb/serial/GobiSerial.c:900: error: ‘struct usb_serial_port’ has no member named ‘console’
drivers/usb/serial/GobiSerial.c:900: error: ‘struct usb_serial_port’ has no member named ‘sysrq’
drivers/usb/serial/GobiSerial.c:905: error: implicit declaration of function ‘usb_serial_handle_sysrq_char’
drivers/usb/serial/GobiSerial.c:912: error: implicit declaration of function ‘usb_serial_generic_resubmit_read_urb’
drivers/usb/serial/GobiSerial.c: In function ‘GobiReadBulkCallback’:
drivers/usb/serial/GobiSerial.c:964: error: ‘urb’ undeclared (first use in this function)
drivers/usb/serial/GobiSerial.c:964: error: (Each undeclared identifier is reported only once
drivers/usb/serial/GobiSerial.c:964: error: for each function it appears in.)
drivers/usb/serial/GobiSerial.c:1110: warning: ISO C90 forbids mixed declarations and code
drivers/usb/serial/GobiSerial.c:1220: error: invalid storage class for function ‘GobiInit’
drivers/usb/serial/GobiSerial.c:1272: error: invalid storage class for function ‘GobiExit’
drivers/usb/serial/GobiSerial.c:1287: error: initializer element is not constant
drivers/usb/serial/GobiSerial.c:1288: error: initializer element is not constant
drivers/usb/serial/GobiSerial.c:1288: warning: ISO C90 forbids mixed declarations and code
drivers/usb/serial/GobiSerial.c:1295: error: invalid storage class for function ‘__check_debug’
drivers/usb/serial/GobiSerial.c:1295: warning: ISO C90 forbids mixed declarations and code
drivers/usb/serial/GobiSerial.c:1297: error: invalid storage class for function ‘__check_flow_control’
drivers/usb/serial/GobiSerial.c:1297: warning: ISO C90 forbids mixed declarations and code
drivers/usb/serial/GobiSerial.c:1299: error: invalid storage class for function ‘__check_ignore_gps_start_error’
drivers/usb/serial/GobiSerial.c:1299: warning: ISO C90 forbids mixed declarations and code
drivers/usb/serial/GobiSerial.c:1300: error: expected declaration or statement at end of input
make[3]: *** [drivers/usb/serial/GobiSerial.o] Error 1
Thanks!
