[ 242.041916] usb 3-6: new high-speed USB device number 6 using xhci_hcd
[ 242.064983] usb 3-6: config 1 has an invalid interface number: 8 but max is 5
[ 242.064995] usb 3-6: config 1 has an invalid interface number: 19 but max is 5
[ 242.065001] usb 3-6: config 1 has an invalid interface number: 20 but max is 5
[ 242.065007] usb 3-6: config 1 has an invalid interface number: 20 but max is 5
[ 242.065013] usb 3-6: config 1 has no interface number 1
[ 242.065018] usb 3-6: config 1 has no interface number 4
[ 242.065024] usb 3-6: config 1 has no interface number 5
[ 242.073008] usb 3-6: New USB device found, idVendor=1199, idProduct=68c0
[ 242.073019] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 242.073026] usb 3-6: Product: Sierra Wireless WP7607
[ 242.073031] usb 3-6: Manufacturer: Sierra Wireless, Incorporated
[ 242.073037] usb 3-6: SerialNumber: VN73048508010300
[ 242.112736] cdc_ether 3-6:1.19 usb0: register ‘cdc_ether’ at usb-0000:00:14.0-6, CDC Ethernet Device, 26:97:8c:2f:bf:48
[ 242.112764] usbcore: registered new interface driver cdc_ether
[ 242.118272] GobiNet: module verification failed: signature and/or required key missing - tainting kernel
[ 242.118947] GobiNet: 2018-03-22/SWI_2.51
[ 242.118995] QMAP Disabled
[ 242.119650] GobiNet 3-6:1.8 eth1: register ‘GobiNet’ at usb-0000:00:14.0-6, GobiNet Ethernet Device, 5a:03:2e:ea:86:f0
[ 242.120512] USB Speed : USB 2.0
[ 242.120540] usbcore: registered new interface driver GobiNet
[ 242.124210] usbcore: registered new interface driver usbserial
[ 242.124285] usbcore: registered new interface driver usbserial_generic
[ 242.125933] usbserial: USB Serial support registered for generic
[ 242.141781] usbcore: registered new interface driver GobiSerial
[ 242.141804] usbserial: USB Serial support registered for GobiSerial
[ 242.142315] GobiSerial 3-6:1.0: GobiSerial converter detected
[ 242.142460] usb 3-6: GobiSerial converter now attached to ttyUSB0
[ 242.143198] GobiSerial 3-6:1.2: GobiSerial converter detected
[ 242.143398] usb 3-6: GobiSerial converter now attached to ttyUSB1
[ 242.145206] GobiSerial 3-6:1.3: GobiSerial converter detected
[ 242.145262] usb 3-6: GobiSerial converter now attached to ttyUSB2
[ 242.145269] GobiSerial: 2018-04-25/SWI_2.32:GobiSerial
[ 260.505161] creating qcqmi0
[ 260.505343] RawIP mode
owner@CNHKG-EX-001367:~$
I’ve measured the power supply and it’s Ok.
We are using our board, developed based on Mango Red.
Is this problem may be related a hardware failure on USB?
I’ve tried to connect with the UART1 sending AT command, but it don’t work too.
