GL7500 PPP Connection issue
Any helps will be appreciated.
Please see log below:
Dec 9 23:45:47 raspberrypi chat[4277]: – got it
Dec 9 23:45:47 raspberrypi chat[4277]: send (AT+CMEE=2^M)
Dec 9 23:45:47 raspberrypi chat[4277]: expect (OK)
Dec 9 23:45:47 raspberrypi chat[4277]: ^M
Dec 9 23:45:47 raspberrypi chat[4277]: OK
Dec 9 23:45:47 raspberrypi chat[4277]: send (AT+CSQ^M)
Dec 9 23:45:47 raspberrypi chat[4277]: +CSQ: 21,2^M
Dec 9 23:45:47 raspberrypi chat[4277]: send (AT+CGDCONT?^M)
Dec 9 23:45:47 raspberrypi chat[4277]: +CGDCONT: 1,“IP”,“pda.bell.ca”,“10.102.34.32”,0,0,0,0,0,0^M
Dec 9 23:45:47 raspberrypi chat[4277]: +CGDCONT: 2,“IPV4V6”,“pda.bell.ca”,"",0,0,0,0,0,0^M
Dec 9 23:45:47 raspberrypi chat[4277]: send (AT+CGACT=1,1^M)
Dec 9 23:45:47 raspberrypi chat[4277]: send (AT+CGATT?^M)
Dec 9 23:45:47 raspberrypi chat[4277]: +CGATT: 1^M
Dec 9 23:45:47 raspberrypi chat[4277]: send (AT+CREG?^M)
Dec 9 23:45:47 raspberrypi chat[4277]: +CREG: 2,1,“2BC4”,“01BA9047”,7^M
Dec 9 23:45:47 raspberrypi chat[4277]: send (AT+CGACT?^M)
Dec 9 23:45:47 raspberrypi chat[4277]: +CGACT: 1,1^M
Dec 9 23:45:47 raspberrypi chat[4277]: +CGACT: 2,0^M
Dec 9 23:45:47 raspberrypi chat[4277]: send (AT+CMEE?^M)
Dec 9 23:45:47 raspberrypi chat[4277]: +CMEE: 2^M
Dec 9 23:45:47 raspberrypi chat[4277]: send (AT+CGATT=1^M)
Dec 9 23:45:48 raspberrypi chat[4277]: expect (OK)
Dec 9 23:45:48 raspberrypi chat[4277]: ^M
Dec 9 23:45:48 raspberrypi chat[4277]: OK
Dec 9 23:45:48 raspberrypi chat[4277]: – got it
Dec 9 23:45:48 raspberrypi chat[4277]: send (ATDT\T^M)
Dec 9 23:45:48 raspberrypi chat[4277]: expect (CONNECT)
Dec 9 23:45:48 raspberrypi chat[4277]: +CREG: 1,“2BC4”,“04BA5330”,7^M
Dec 9 23:45:48 raspberrypi chat[4277]: +CREG: 1,“2BC4”,“04BA5330”,6^M
Dec 9 23:45:48 raspberrypi chat[4277]: +CGREG: 1,“2BC4”,“04BA5330”,6,“79”^M
Dec 9 23:45:48 raspberrypi chat[4277]: +CEREG: 1,“2BDD”,“04BA5330”,6^M
Dec 9 23:45:50 raspberrypi chat[4277]: ^M
Dec 9 23:45:50 raspberrypi chat[4277]: +CUSD: 2^M
Dec 9 23:45:50 raspberrypi chat[4277]: +CME ERROR: Incorrect Parameters^M
Dec 9 23:45:51 raspberrypi chat[4277]: ^M
Dec 9 23:45:51 raspberrypi chat[4277]: +CGEV: NW MODIFY 1,2,0^M
Dec 9 23:45:54 raspberrypi chat[4277]: ^M
Dec 9 23:45:54 raspberrypi chat[4277]: +CEREG: 1,“2BDD”,“01BA9047”,6^M
Dec 9 23:45:55 raspberrypi chat[4277]: ^M
Dec 9 23:45:55 raspberrypi chat[4277]: +CREG: 1,“2BC4”,“01BA9047”,7^M
Dec 9 23:45:55 raspberrypi chat[4277]: +CGREG: 1,“2BC4”,“01BA9047”,7,“79”^M
Dec 9 23:45:55 raspberrypi chat[4277]: +CEREG: 1,“2BDD”,“01BA9047”,7^M
Dec 9 23:45:55 raspberrypi chat[4277]: +CGEV: NW MODIFY 1,2,0^M
Dec 9 23:46:10 raspberrypi chat[4277]: ^M
Dec 9 23:46:10 raspberrypi chat[4277]: +CEREG: 1,“2BDD”,“01BA9001”,7^M
Dec 9 23:46:10 raspberrypi chat[4277]: +CREG: 0^M
Dec 9 23:46:10 raspberrypi chat[4277]: +CGREG: 0^M
Dec 9 23:46:10 raspberrypi chat[4277]: +CEREG: 0^M
Dec 9 23:46:10 raspberrypi chat[4277]: +CREG: 1,“2BC4”,“01BA900B”,7^M
Dec 9 23:46:10 raspberrypi chat[4277]: +CGREG: 1,“2BC4”,“01BA900B”,7,“79”^M
Dec 9 23:46:10 raspberrypi chat[4277]: +CEREG: 1,“2BDD”,“01BA900B”,7^M
Dec 9 23:46:33 raspberrypi chat[4277]: alarm
Dec 9 23:46:33 raspberrypi chat[4277]: Failed
Dec 9 23:46:34 raspberrypi pppd[4273]: Exit.
Hi @pcho
Which firmware version are you using? If you are not in the latest firmware, please download the latest one and retry.
You can get the firmware here: Firmware
Continuing the discussion from GL7500 PPP Connection issue:
I am using
ATI9
GL7500.A.2.13.151600.201802201800.x7160_1
GL7500
GL7500.A.2.13
x7160
FUSED
2018-02-20 18:20:46
r12350
Is there any difference between HL7588 and HL7688 in
term of connectivity?
Hi pcho,
It is not the latest firmware version. Please download the latest one and retry.
No, there is not.
Please find the PPP configuration and log files for your reference. PPPD.zip (2.7 KB)
Help to mark “Solution” if your question is answered.
Hi Donald,
I am planning to abandon PPP and migrate to wwan interface.
I was able to connect using AT commands
Like belows:
AT+CGACT=1,1
AT+CGPADDR=1
AT+XDNS?
AT+XDATACHANNEL=1,1,"/USBCDC/0","/USBHS/NCM/0",2,1
AT+CGDATA=“M-RAW_IP”,1
Routing Table
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default hitronhub.home 0.0.0.0 UG 0 0 0 wlan0
192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan0
then I set my network (debian OS) as instructed on Sierra Wireless manual
sudo ifconfig wwan0 10.102.34.3 netmask 255.255.255.0 arp up
sudo route add default wwan0
default 0.0.0.0 0.0.0.0 U 0 0 0 wwan0
default 192.168.0.1 0.0.0.0 UG 0 0 0 wlan0
10.102.34.0 0.0.0.0 255.255.255.0 U 0 0 0 wwan0
Then I ping to 8.8.8.8 (ping -I wwan0 -c4 8.8.8.8)
I got an error not reachable
It seems like something is missing or I did something wrong.
Any help will be appreciated.
Regards,
Phillip
Hi pcho
Please follow the attached documents Data call using NCM interface.docx (694.6 KB)
