Thank you. This link was helpful.
Receiving Messages ist not a problem.
However, I have problems sending them.
I try to send every 10 seconds a message with pbuf=#001(CR) (a CarriageReturn is needed for this command)
ret = adl_fcmSendData(handle_uart1, ( u8 * )pbuf, ( u16 )(5) );
in the function FCM_Command_handler(see code below).
It sends the ASCII order via the RS232.
ret:0 handle:0 pbuf:#001 len:4
However, it won’t send a response.
I’ve made also these settings
/* Databit= 8, Stopbit=1, Parity= none => AT Command Interface page 1003 : 3,4 */
adl_atCmdCreate(“AT+ICF=3,4”, UART_1,NULL,NULL);
/* no hardware flow control */
adl_atCmdCreate(“AT+IFC=0,0”,UART_1,NULL,NULL);
Then shortly this:
ret:1 handle:0 pbuf:#001 len:4
and finally this with the error -21
ret:-21 handle:0 pbuf:#001 len:4
#include "wm_types.h"
#include "wm_stdio.h"
#include "wm_list.h"
#include "adl_str.h"
#include "adl_port.h"
#include "adl_at.h"
#include "adl_traces.h"
#include "adl_memory.h"
#include "adl_error.h"
#include "adl_fcm.h"
#include "adl_TimerHandler.h"
#include "adl_AppliInit.h"
#include "adl_UnSoHandler.h"
#include "adl_RspHandler.h"
#include "adl_CmdStackHandler.h"
#include "adl_global.h" /* Application development layer */
#include "adl_adc.h"
/*-------------------------------- defines -------------------------------*/
#define UART_1 ADL_AT_PORT_TYPE(ADL_PORT_UART1,ADL_AT_RSP) /* refer to ADL User Guide pag 67, rspflag */
// Application tasks prototypes
extern void main_task ( void );
void FCM_Command_handler( u8 ID, void * Context );
bool FcmCtrlHandler(adl_fcmEvent_e evnt);
static bool FcmDataHandler(u16 DataSize, u8 * Data);
#ifndef __GNU_GCC__
#define DECLARE_CALL_STACK(X) (X)
#else
#define DECLARE_CALL_STACK(X) (X*3)
#endif /* #ifndef __GNU_GCC__ */
// Application tasks declaration table
const adl_InitTasks_t adl_InitTasks [] =
{ main_task, DECLARE_CALL_STACK ( 1024 ), "main", 1 },
{ 0, 0, 0, 0 }
/* UART mode type */
enum UART_TYPE{
DATAMODE,
ATMODE
/*------------------------------ variables ---------------------------*/
const u16 wm_apmCustomStackSize = 1024*3; /* application stack size (trial&error to determine size)*/
s8 handle_uart1; /* UART1 handler */
u8 mode_uart1; /* UART1 mode type */
ascii *saveFCMdata; //saves last message received from FCM
* FCM control handler
switch (evnt)
/* when com is open, operation mode is defined */
case ADL_FCM_EVENT_FLOW_OPENNED:
/* DATA MODE */
if(mode_uart1 == DATAMODE){
adl_atSendResponse(ADL_AT_RSP, "\r\nUART1: Data Mode");
adl_fcmSwitchV24State(handle_uart1,ADL_FCM_V24_STATE_DATA);
/* AT MODE */
else if(mode_uart1 == ATMODE){
adl_atSendResponse(ADL_AT_RSP, "\r\nUART1: AT Mode");
adl_fcmSwitchV24State(handle_uart1,ADL_FCM_V24_STATE_AT);
break;
case ADL_FCM_EVENT_V24_DATA_MODE:
/* DATA MODE OK */
break;
case ADL_FCM_EVENT_V24_AT_MODE:
/* AT MODE OK */
break;
case ADL_FCM_EVENT_RESUME:
break;
case ADL_FCM_EVENT_MEM_RELEASE:
break;
default:
return FALSE;
break;
return TRUE;
* FCM data handler
ascii buf[100] = { 0 };
u16 i = 0;
wm_sprintf(buf,"\r\nDataSize:%d|\r\n",DataSize);
adl_atSendResponse ( ADL_AT_UNS, buf );
wm_sprintf(buf,"\r\nData:\r\n%s[%d]|\r\n",Data,(int)Data);
saveFCMdata = malloc(DataSize * sizeof(char) );
adl_atSendResponse ( ADL_AT_UNS,"\r\n-----------------\r\n");
for(i=0 ; i < DataSize ;i++)
wm_sprintf(buf,"%c",Data[i]);
saveFCMdata[i] = Data[i];
return true;
//Send command every 10 seconds
ascii buf[100];
s8 ret;
ascii * pbuf;
u16 len;
pbuf = "#001";
pbuf[4]=13;//CR
pbuf[5]='\0';
len = (u16)wm_strlen(pbuf) +1; //+1 for CR
ret = adl_fcmSendData(handle_uart1, ( u8 * )pbuf, ( u16 ) ( wm_strlen(pbuf)+1) ); //ret = adl_fcmSendData(handle_uart1, pbuf, &len);
if( ret != 0)
wm_sprintf(buf, "adl_fcmSendData err = %d\r\n", ret);
adl_atSendResponse ( ADL_AT_UNS, buf);
wm_sprintf(buf, "ret:%d handle:%d pbuf:%s len:%d \r\n", ret, handle_uart1, pbuf, len);
switch(ret){
case ADL_RET_ERR_PARAM:
adl_atSendResponse(ADL_AT_RSP,"FCM send data: parameter incorrect value");
break;
case ADL_RET_ERR_UNKNOWN_HDL:
adl_atSendResponse(ADL_AT_RSP,"FCM send data: unknown handle");
break;
case ADL_RET_ERR_BAD_STATE:
adl_atSendResponse(ADL_AT_RSP,"FCM send data: not ready to send data");
break;
case ADL_FCM_RET_ERR_WAIT_RESUME:
adl_atSendResponse(ADL_AT_RSP,"FCM send data: flow has no more credit");
break;
case ADL_RET_ERR_SERVICE_LOCKED:
adl_atSendResponse(ADL_AT_RSP,"FCM send data: from a low level");
break;
/* Function : main_task */
/* Object : Customer application initialization */
adl_InitType_e InitType = adl_InitGetType ();
ascii buf[100];
mode_uart1 = DATAMODE;
/* speed with AT Command*/
adl_atCmdCreate("AT+IPR=9600", UART_1,NULL ,NULL);
// adl_atCmdCreate("AT+ICF=3,4", UART_1,NULL,NULL);
//adl_atCmdCreate("AT+IFC=0,0",UART_1,NULL,NULL);
handle_uart1=adl_fcmSubscribe(ADL_PORT_UART1, FcmCtrlHandler, FcmDataHandler);
wm_sprintf(buf, "\r\nhandle_uart1:%d \r\n", handle_uart1);
adl_atSendResponse(ADL_AT_RSP,buf);
if(adl_fcmIsAvailable(ADL_FCM_FLOW_V24_UART1))
adl_atSendResponse ( ADL_AT_UNS, "\r\nUART1 is available.\r\n" );
//set Timer FCM_Command to send command every 10 seconds
adl_tmrSubscribe (TRUE, 100, ADL_TMR_TYPE_100MS, FCM_Command_handler );
Can anyone tell what went possibly wrong here?
Thank you.
