I have bit of a problem. I cannot seem to pass pointer as a return parameter to a function in a separate module.
Given a function:
void func( typeZ * ptr );
Defined in a module called A.c like:
void func( typeZ* ptr)
ptr = &var;
Where var is native to A.c:
typeZ var;
Now given a calling process that uses this function:
func( param );
Where the param is:
typeZ *param;
Always returns with param = NULL.
I have tried this with static and volatile keywords on the param veriable, and it still does not work. I would seem that the param parameter is properly assigned, but upon exit of the function call, the param parameter vanishes???
I think this is a problem with scope. I am using VS c/c++ 6.0. What is wrong?
Thanks.
