Hi Everybody,
I am having trouble with the command [ETX]…
First of all, I have downloaded the WIPSoft Sample to my Fastrack Supreme 20 modem, in order to make the WIP AT Command available and indeed, all of them work fine, so I tried to use the example of the manual (wipat.pdf) in the section of FTP in order to upload a file and everything goes fine until I get connected…
Once I am connected, I begin to write the data of the file and then I write [ETX] in order to provoke an “End of Transmission” but anything happens…I have to stop my application, in this case the WipSoft and then I must disconnect it manually and after 20 or 30 minutes the file appears in the server…
So here the question is…Why cant I see the [ETX] response??? I should see an “OK” for Response but I do not see anything!!!
What am I doing bad? who can help me???..Awneil, do you know the answer? you always do…please!!!
