Error in TCP Connection
I am getting error while using CGDCONT=1,“IPV6” but works fine with CGDCONT=1,“IP”
not able to understand the issue, kindly help
[2025-02-26 20:59:53] AT+CGMM
[2025-02-26 20:59:53] HL7692
[2025-02-26 20:59:53] OK
[2025-02-26 20:59:53] AT+CGMI
[2025-02-26 20:59:53] Sierra Wireless
[2025-02-26 20:59:53] ATI3
[2025-02-26 20:59:53] RHL769x.2.27.183100.201809071813.x7120m_3
[2025-02-26 20:59:54] +CGREG: 1
[2025-02-26 20:59:57] +SIM: 1
[2025-02-26 20:59:57] +KSUP: 0
[2025-02-26 21:00:04] +PBREADY
[2025-02-26 21:00:04] AT+CGDCONT=1,“IP”,“airtelgprs.com”
[2025-02-26 21:00:11]
[2025-02-26 21:00:11] OK
[2025-02-26 21:00:11] AT+CFUN=1,1
[2025-02-26 21:00:23]
[2025-02-26 21:00:23] OK
[2025-02-26 21:00:23] +CGREG: 0
[2025-02-26 21:00:28] +CGREG: 2
[2025-02-26 21:00:28] +WDSI: 0
[2025-02-26 21:00:31] +CGREG: 1
[2025-02-26 21:00:34] +SIM: 1
[2025-02-26 21:00:34] +KSUP: 0
[2025-02-26 21:00:40] +PBREADY
[2025-02-26 21:00:40] AT+KCNXCFG=1,“GPRS”,“airtelgprs.com”,“”,“”
[2025-02-26 21:00:44]
[2025-02-26 21:00:44] OK
[2025-02-26 21:00:44] AT+CGPADDR=1
[2025-02-26 21:00:56]
[2025-02-26 21:00:56] +CGPADDR: 1,“100.71.128.80”
[2025-02-26 21:00:56] OK
[2025-02-26 21:00:56] AT+KCNXTIMER=1,30,3
[2025-02-26 21:01:03]
[2025-02-26 21:01:03] OK
[2025-02-26 21:01:03] AT+KCNXUP=1
[2025-02-26 21:01:09]
[2025-02-26 21:01:09] OK
[2025-02-26 21:01:09] +KCNX_IND: 1,4,1
[2025-02-26 21:01:09] +KCNX_IND: 1,1,0
[2025-02-26 21:01:09] AT+KTCPCFG=1,0,“www.google.com”,“80”
[2025-02-26 21:01:20]
[2025-02-26 21:01:20] +KTCPCFG: 1
[2025-02-26 21:01:20] OK
[2025-02-26 21:01:20] AT+KTCPSTART=1
[2025-02-26 21:01:28]
[2025-02-26 21:01:28] +KTCP_IND: 1,1
[2025-02-26 21:01:28] CONNECT
[2025-02-26 21:04:21] NO CARRIER
[2025-02-26 21:04:21] +KTCP_NOTIF: 1,4
[2025-02-26 21:04:21] AT+KCNXDOWN=1,1
[2025-02-26 21:10:51]
[2025-02-26 21:10:51] OK
[2025-02-26 21:10:51] +KCNX_IND: 1,0,0
[2025-02-26 21:16:50] +SIM: 1
[2025-02-26 21:16:50] +KSUP: 0
[2025-02-26 21:16:52] +CGREG: 1
[2025-02-26 21:16:53] +PBREADY
[2025-02-26 21:16:53] AT+CGDCONT=1,“IP”,“airtelgprs.com”
[2025-02-26 21:16:57]
[2025-02-26 21:16:57] OK
[2025-02-26 21:16:57] AT+CFUN=1,1
[2025-02-26 21:17:04]
[2025-02-26 21:17:04] OK
[2025-02-26 21:17:04] +CGREG: 0
[2025-02-26 21:17:09] +CGREG: 2
[2025-02-26 21:17:09] +WDSI: 0
[2025-02-26 21:17:12] +CGREG: 1
[2025-02-26 21:17:15] +SIM: 1
[2025-02-26 21:17:15] +KSUP: 0
[2025-02-26 21:17:21] +PBREADY
[2025-02-26 21:17:21] AT+KCNXCFG=1,“GPRS”,“airtelgprs.com”,“”,“”
[2025-02-26 21:17:38]
[2025-02-26 21:17:38] OK
[2025-02-26 21:17:38] AT+CGPADDR=1
[2025-02-26 21:17:47]
[2025-02-26 21:17:47] +CGPADDR: 1,“FE80:0:0:0:2:1:AAD5:2F99”
[2025-02-26 21:17:47] OK
[2025-02-26 21:17:47] AT+KCNXTIMER=1,30,3
[2025-02-26 21:18:04]
[2025-02-26 21:18:04] OK
[2025-02-26 21:18:04] AT+KCNXUP=1
[2025-02-26 21:18:12]
[2025-02-26 21:18:12] OK
[2025-02-26 21:18:12] +KCNX_IND: 1,4,1
[2025-02-26 21:18:12] +KCNX_IND: 1,2,1,3,30
[2025-02-26 21:18:12] AT+KTCPCFG=1,0,“www.google.com”,“80”
[2025-02-26 21:18:23]
[2025-02-26 21:18:23] +KTCPCFG: 1
[2025-02-26 21:18:23] OK
[2025-02-26 21:18:23] AT+KTCPSTART=1
[2025-02-26 21:18:30]
[2025-02-26 21:18:30] +KCNX_IND: 1,4,1
[2025-02-26 21:18:30] +KCNX_IND: 1,2,1,3,30
[2025-02-26 21:19:00] +KCNX_IND: 1,4,2
[2025-02-26 21:19:00] +KCNX_IND: 1,2,2,3,30
[2025-02-26 21:19:30] +KCNX_IND: 1,4,3
[2025-02-26 21:19:30] +KCNX_IND: 1,2,3,3,30
[2025-02-26 21:19:30] +KTCP_NOTIF: 1,0
I don’t quite see IPV6 is set:
@jyijyi I missed some lines while pasting, kindly check the below
[2025-02-26 21:16:46] AT+CGMM
[2025-02-26 21:16:46] HL7692
[2025-02-26 21:16:46] OK
[2025-02-26 21:16:46] AT+CGMI
[2025-02-26 21:16:46] Sierra Wireless
[2025-02-26 21:16:46] ATI3
[2025-02-26 21:16:46] RHL769x.2.27.183100.201809071813.x7120m_3
[2025-02-26 21:16:53] AT+CGDCONT=1,“IPV6”,“airtelgprs.com”
how about you use the IPV6 address of google in AT+KTCPCFG?
you might also specify IPv6 when using +KTCPCFG:
