error: Couldn't find component 'embeddedOracleJvm'.
#1
Hi
I’ve been trying to get the legato java hello world example running all afternoon. It seems it can’t find EJDK. I want to run it on a mangOH device so I download the ARM v6/v7 Linux EJDK from this page
oracle.com/technetwork/java/ … index.html
according to this guide:
legato.io/legato-docs/latest/javaBuild.html
I’m using a windows machine and the Legato Ubuntu virtual machine that was recommended for the mangOH setup in this document:
mangoh.io/docs/4118961_WinCLI%20 … als_r4.pdf
$ mkapp -v -t wp85 javaHelloWorld.adef Env var 'EJDK_DIR=/home/legato/Downloads/ejdk1.8.0_101/linux_armv6_vfp_hflt/compact1' became 'XDG_VTNR=7'. Environment variables are different this time. Parsing file: '/home/legato/legato/packages/legato.framework.16.4.0.I201606090927/resources/legato/apps/javaHelloWorld2/javaHelloWorld.adef'. Modelling application: 'javaHelloWorld' defined in: '/home/legato/legato/packages/legato.framework.16.4.0.I201606090927/resources/legato/apps/javaHelloWorld2/javaHelloWorld.adef' Application 'javaHelloWorld' contains executable 'helloWorld'. Parsing file: '/home/legato/legato/packages/legato.framework.16.4.0.I201606090927/resources/legato/apps/javaHelloWorld2/javaHelloComponent/Component.cdef'. Modelling component: 'javaHelloComponent' found at: '/home/legato/legato/packages/legato.framework.16.4.0.I201606090927/resources/legato/apps/javaHelloWorld2/javaHelloComponent' ** ERROR: /home/legato/legato/packages/legato.framework.16.4.0.I201606090927/resources/legato/apps/javaHelloWorld2/javaHelloComponent/Component.cdef:11:8: error: Couldn't find component 'embeddedOracleJvm'.
I’ve set up the the environment variables in my .bash_profile according to the instructions:
$ echo $JAVA_HOME /usr/lib/jvm/java-1.8.0-openjdk-amd64 $ echo $EJDK_DIR /home/legato/Downloads/ejdk1.8.0_101/linux_armv6_vfp_hflt/compact1 legato@legato-VirtualBox:~/legato/packages/legato.framework.16.4.0.I201606090927/resources/legato/apps/javaHelloWorld2$
I’m sorry for the wall of text but I wanted to get in all the relevant information.
Has anyone experienced anything similar?
#2
This embeddedOracleJvm component is provided by the framework itself.
To make it reachable by mkapp, you need to add the -s ${LEGATO_ROOT}/components option to your command line.
#3
Thank you so much!
I love you and the internet
