Hi all,
Within a Q26 running openAT, Is it possible to issue an AT command to enable UART2 (so it may be used as a firmware download port) then saving the setting in non-volatile memory.
So next time power is applied to the unit, UART2 is enabled with no further action required.
Mark
awneil
June 13, 2011, 10:25am
2
Note Open-AT has only UARTs - not US ARTs
Yes - but see:
But note that R7.4 opens the USB port automatically - this is a change from earlier firmware.
The need to enable USB (and UART2) before it can be used:
wavecom.com/modules/movie/sc … 518#p15518
Update (2010):
R7.4 (and later) opens the USB port automatically - this is a change from earlier firmware.
Ya i also experienced the same thing.If the port is already opened and you try to open it it gives +CME ERROR 3
See your other post on the same subject:
The AT Commands Manual for your particular version will state any limitations on this.
Recent version support AT+WDWL on any UART (including USB); earlier versions didn’t
Again, The AT Commands Manual documents whether settings are saved with or without an explicit command.
It is easier to check whether UART2 is activated with AT commands.
