EM7565 set APN per SIM slot
Hi there,
Does anyone know if it’s possible to assign APNs (or PDP contexts/profiles) to a specific SIM slot? I want to use two different carriers with different APNs.
The other issue I have is that both carriers authorize successfully with no APN or incorrect APN information, they just don’t forward your data outside the network.
I need to do this via AT commands (if at all possible).
Thanks.
You can use at!uims to switch sim and then use at+cgdcont to change APN
Thank you. I was hoping I could do it as a one off config, but other sources tell me it may need to be an application thing that does what you’ve suggested.
