EM7455 auto-sim
Hi, I have a EM7455 on a Linux platform. What AT command can I use to determine if auto SIM is turned OFF or ON?
Model: EM7455
Revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
MEID: 35907306139482
IMEI: 359073061394825
IMEI SV: 12
FSN: LF833300780110
+GCAP: +CGSM
Firmware & Carrier Configuration Images:
FW 1 GOOD 2 0 0 ?? 02.24.05.06?
FW 2 GOOD 1 0 0 ?? 02.24.03.00?
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.027_000 02.24.05.06_ATT
PRI FF GOOD 0 0 0 002.026_000 02.24.05.06_GENERIC
PRI FF GOOD 0 0 0 002.022_000 02.24.03.00_SPRINT
PRI FF GOOD 0 0 0 001.000_000 00.00.00.00_OEMPRI918
PRI FF GOOD 0 0 0 002.034_000 02.24.05.06_VERIZON
Max PRI images: 50
Current & Preferred Images:
preferred fw version: 02.24.05.06
preferred config name: GENERIC_002.026_000
current fw version: 02.24.05.06
current carrier name: GENERIC
current config name: GENERIC_002.026_000
@dchou4u,
If you send at!impref? to the unit and it is set to auto-SIM then the ‘preferred carrier name’ will be set to AUTO-SIM, if it is set to anything else then it is not on.
