Satellite searched but no gva data
How to fix
what is the return of AT!GPSSATINFO?
Have you tried with AT!GPSFIX command with larger maximum distance?
Which FW are you using in ATI3?
FW 02.33.03
FIX=1,255,1000
WHY NO SAT INFO??
did you connect the GPS antenna?
Are you testing in outdoor area?
Testing in indoor, but right near the window
did you try to connect the GPS antenna?
Do I need to install both the main antenna and the GPS antenna? When I connected the main antenna to the GPS connector, the symptoms were the same.
yes, i think so, you need to connect both antenna and test in outdoor area
ok. I’m planning to test the antenna I purchased once it arrives. thankyou
