Hi All.
Having some issues moving a project from R7.43 firmware to R7.45 using DS 2.1.0 (for both projects).
The R7.43 project was originally created using the SDK profile ‘OpenAT Embedded Software Suite package (2.33.0.201009161739)’
The R7.43 project has the Application settings editor disabled with task table (and associated constants) hard coded into the main.c source file. This has worked extremely well.
I created a new project based on the SDK profile ‘OpenAT Embedded Software Suite package (2.35.201107291230)’, copied my existing source and headers into the new project tree, and used the Application settings editor to generate the correct mos_headerSEList[] etc.
A ‘Clean Project’ correctly builds the dwl and associated files.
I then copied the contents of generated.c into the main.c (as done previously) and disabled the Application settings editor (which removes generated.[ch]).
A ‘Clean Project’ appears to build all the object files, but fails near the end of the process when invoking ‘python.exe’ with the following error:
C:\OpenAT-2.36-DS-2.1.0\Developer Studio\tools\armelfgcc\4.0.1\bin\arm-elf-gcc.exe -D__OAT_API_VERSION__=635 -D__CGPS_PLUGIN_VERSION__=107 -D__WIP_PLUGIN_VERSION__=541 -D__DEBUG_APP__ -DDS_DEBUG -D__arm -D__GNU_GCC__ -IC:\OpenAT-2.36-DS-2.1.0\Developer Studio\dropins\com.wavecom.openat.ide.spm.lib.os.model.6.35.0.201102280758_6.35.0.201102280758\resources/ADL/itf -IC:\OpenAT-2.36-DS-2.1.0\Developer Studio\dropins\com.wavecom.openat.ide.spm.lib.os.model.6.35.0.201102280758_6.35.0.201102280758\resources/ADL/basic -IC:\OpenAT-2.36-DS-2.1.0\Developer Studio\dropins\com.wavecom.openat.ide.spm.lib.plugin.model.C-GPS-OPUS-I.1.7.0.2010_1.7.0.2010\resources/C-GPS-OPUS-I/itf -IC:\OpenAT-2.36-DS-2.1.0\Developer Studio\dropins\com.wavecom.openat.ide.spm.lib.plugin.model.WIP.5.41.0.201102280815_5.41.0.201102280815\resources/WIP/itf -IR:\Design\0066.LeonardiPartyBus\Software\OpenAT-2.36-DS2.1.0\PB-0.6.0\itf -IR:\Design\0066.LeonardiPartyBus\Software\OpenAT-2.36-DS2.1.0\PB-0.6.0\inc -O0 -Os -ggdb3 -Wall -c -fshort-enums -fdollars-in-identifiers -nostartfiles -fno-strict-aliasing -fno-common -fomit-frame-pointer -mthumb-interwork -mthumb -march=armv5te -msoft-float -mfpu=fpa -mapcs -mno-apcs-stack-check -osrc\Event\createevent.o ..\src\Event\createevent.c
C:\OpenAT-2.36-DS-2.1.0\Developer Studio\tools\armelfgcc\4.0.1\bin\arm-elf-g++.exe -Wl,--script,gcc.lkopt src\voice.o src\tcu.o src\sms.o src\main.o src\gps.o src\event.o src\digitalio.o src\configuration.o src\comms.o src\comms\comms_smtphandlers.o src\comms\comms_ftphandlers.o src\comms\comms_datahandler.o src\comms\comms_datacevwrite.o src\comms\comms_datacevread.o src\comms\comms_datacevopen.o src\comms\comms_dataceverror.o src\adFlash\adwrite.o src\adFlash\adrecompact.o src\adFlash\adread.o src\adFlash\adopen.o src\adFlash\adinit.o src\adFlash\adformat.o src\adFlash\adfinalize.o src\adFlash\adeventhandler.o src\adFlash\addelete.o src\adFlash\adclose.o src\Main\handlerwind15.o src\Main\handlerwhcnf.o src\Main\handlercgsn.o src\Main\handlerat.o src\Main\gprs.o src\Helpers\millimetertometer.o src\Helpers\gccspecific.o src\Helpers\doubletostring.o src\Helpers\consoleoutput.o src\Helpers\bround.o src\Event\formatEventLogitem.o src\Event\eventlist.o src\Event\createevent.o src\Event\buildjsoneventstring.o src\Event\broadcasttaskmsg.o src\CGps\eride.o src\CGps\cpgsgpio.o src\CGps\cgpscore.o src\CGps\cgpsconstants.o -Wl,-( -nostartfiles -Os -O2 -fshort-enums -fdollars-in-identifiers -ggdb3 -fomit-frame-pointer -mthumb-interwork -mthumb -march=armv5te -msoft-float -mfpu=fpa -mapcs -mno-apcs-stack-check -Wl,-nmagic -Wl,-Map,PB-0.6.0.map C:\OpenAT-2.36-DS-2.1.0\Developer Studio\dropins\com.wavecom.openat.ide.spm.lib.os.model.6.35.0.201102280758_6.35.0.201102280758\resources\ADL\ARM_ELF_GCC_ADL.lib C:\OpenAT-2.36-DS-2.1.0\Developer Studio\dropins\com.wavecom.openat.ide.spm.lib.plugin.model.C-GPS-OPUS-I.1.7.0.2010_1.7.0.2010\resources\C-GPS-OPUS-I\gcc_CGPS_0.0.0.5.1.lib C:\OpenAT-2.36-DS-2.1.0\Developer Studio\dropins\com.wavecom.openat.ide.spm.lib.plugin.model.WIP.5.41.0.201102280815_5.41.0.201102280815\resources\WIP\ARM_ELF_GCC_WIP.lib C:\OpenAT-2.36-DS-2.1.0\Developer Studio\dropins\com.wavecom.openat.ide.spm.lib.plugin.model.WIP.5.41.0.201102280815_5.41.0.201102280815\resources\WIP\ARM_ELF_GCC_WIPSoftLib.lib -Wl,-) -oPB-0.6.0.axf
C:\OpenAT-2.36-DS-2.1.0\Developer Studio\plugins\com.wavecom.openat.ide.ebs.build.core.win32_2.1.0.201108080830-R7547\os\win32\python\python.exe -E C:\OpenAT-2.36-DS-2.1.0\Developer Studio\plugins\com.wavecom.openat.ide.ebs.armelfgcc_2.1.0.201108080830-R7547\scripts\fromelf.py C:\OpenAT-2.36-DS-2.1.0\Developer Studio\plugins\com.wavecom.spm.utils_1.2.2.201107261502-R7480\elfutils PB-0.6.0.axf PB-0.6.0.cpbin
Traceback (most recent call last):
File "C:\OpenAT-2.36-DS-2.1.0\Developer Studio\plugins\com.wavecom.openat.ide.ebs.armelfgcc_2.1.0.201108080830-R7547\scripts\fromelf.py", line 15, in <module>
parsedElf = ElfFile ( file ( AXFFile, "rb" ) )
IOError: [Errno 2] No such file or directory: 'PB-0.6.0.axf'
Build error occurred, build is stopped
As you can see, it appears that the linker is not building the .axf file correctly - but does not appear to be throuwing an error.
Finally, If I revert the project SDK profile back to 2.33 (without the application settings editor), the code compiles correctly.
What am I missing?
ciao, Dave
