Several things have to be verified…
1* Is this compiler able to produce ARM EABI code (as GCC or RVDS do)? If not, then it’s over, since you won’t be able to link your code against Open AT libraries (built for ARM EABI).
2* Then, the easy way would be that this MDK compiler uses options syntax similar to other ARM ones. If this is the case, you could give a try to customize - for example - ARM RVDS installation paths (in Windows > Preferences > Developer Studio > Tools Path > RVDS), and various compiler options to try to get it compile and link against our libs.
3* And if not (I mean if the options syntax is really completely different), I’m afraid that someone need to do some java and Eclipse code to develop a DS add-on able to integrate this particular toolchain. That’s the moment to remind that DS code is opened, and that it’s possible to develop (and even maybe contribute) add-ons: forum.sierrawireless.com/viewto … 108&t=5727 ![]()
