I’m trying to request raw GPS data from my MC7750 card using ModemManager. Every step seems to work perfectly up until receiving the actual RAW gps data. For some reason all I am able to receive is GLGSV data. Maybe I’m missing a step, but I just can’t figure this out. My goal is just to be able to receive coord/UTM data.
Everything seems to enable just fine as shown below:
$ mmcli -m 0 --enable
successfully enabled the modem
$ mmcli -m 0 --location-enable-gps-nmea --location-enable-gps-raw --location-disable-3gpp
successfully setup location gathering
$ mmcli -m 0 --location-status
Location | capabilities: 3gpp-lac-ci, gps-raw, gps-nmea, cdma-bs, agps-msa, agps-msb
| enabled: gps-raw, gps-nmea
| signals: yes
GPS | refresh rate: 30 seconds
$ mmcli -m 0 --location-get
GPS | nmea: $GPGSA,A,1,,,,,,,,,,,,,,,*1E
| $GNGNS,,,,,,NN,,,,,,*53
| $GPRMC,,V,,,,,,,,,,N*53
| $PSTIS,*61
| $GNGSA,A,1,,,,,,,,,,,,,,,*00
| $GPGSV,3,1,09,01,17,043,,05,,,,06,26,160,,07,,,*75
| $GPGSV,3,2,09,08,,,,09,,,,13,30,227,,22,,,*46
| $GPGSV,3,3,09,23,,,*71
| $GLGSV,3,1,09,66,,,,86,59,050,,77,43,330,,76,61,066,*58
| $GLGSV,3,2,09,79,,,,87,45,182,,85,14,028,,67,09,275,*5C
| $GLGSV,3,3,09,68,07,322,*56
| $GPVTG,,T,,M,,N,,K,N*2C
| $GPGGA,,,,,,0,,,,,,,,*66
If I try to run “mmcli -m 0 --location-get-gps-raw”, it returns with “error: no actions specified”
Here’s my Modem Status as well if it helps
$ mmcli -m 0
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: e8162efb86655cf95045d2f59fb0d36c82e4a49c
Hardware | manufacturer: Sierra Wireless, Incorporated
| model: MC7750
| firmware revision: SWI9600M_03.05.10.13ap r6237 cnszxd00000132 2014/04/18 16:55:52
| h/w revision: 20
| supported: gsm-umts, lte
| cdma-evdo, lte
| lte
| cdma-evdo, gsm-umts, lte
| current: cdma-evdo, lte
| equipment id: 990000780819803
System | device: /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6
| drivers: qcserial, qmi_wwan
| plugin: sierra
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB2 (at),
| wwp0s26u1u6i8 (net)
Numbers | own: 197######56
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: registered
| power state: on
| access tech: lte
| signal quality: 88% (cached)
Modes | supported: allowed: 2g; preferred: none
| allowed: 3g; preferred: none
| allowed: 2g, 3g; preferred: 3g
| allowed: 2g, 3g; preferred: 2g
| allowed: 2g, 4g; preferred: 4g
| allowed: 2g, 4g; preferred: 2g
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 2g
| current: allowed: 2g, 3g, 4g; preferred: 2g
Bands | supported: eutran-13, cdma-bc0, cdma-bc1
| current: eutran-13, cdma-bc0, cdma-bc1
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 990000780819803
| enabled locks: fixed-dialing
| operator id: 311480
| operator name: Home
| registration: home
3GPP EPS | ue mode of operation: ps-2
CDMA | meid: A00000E6207668
| esn: 80E2832B
| activation: activated
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
I’ve tried using other gps utilities, as well as using ModemManager-gui to no avail.
Any help with this issue would be greatly appreciated. (:
