I have succesfully subscribed and transferred data via UART1 using adl flow control. However , I need to change the baud rate to a value determined at runtime , so I have implemented the following , inter alia :
// first set baudrate while still in AT mode
wm_sprintf(s,"at+ipr=%u",V24FCMBaudRate); // eg V24FCMBaudRate = 9600
adl_atCmdCreate(s,TRUE, (adl_atRspHandler_t) V24FCMSetBaudCmdResponseHandler,"OK","ERROR","+CME",NULL );
// first we will wait for the AT commands to execute, then subscribe to flow
The command handler V24FCMSetBaudCmdResponseHandler is executed ok (under ADL_STR_OK case) and I subscribe within that command handler to the flow. The flow then works fine.The only problem is that the baud rate does not change , it remains at default 115200. So, it appears that the new baud rate request has been rejected , although the command event handler suggests that the command executed correctly.
I have really exhausted all my options , so , please , can anyone suggest a possible bug or perhaps an alternate option ?
I think it might solve your problem.
