thanks a lot for your help !
I use ppp because it works well with my other modem (SIM7100E), and it was in place when I arrived in this company
=> All these commands are sent when the modem is disconnected (because it says it’s locked when it’s connected…) : so btw is there an option to connect to with minicom while the modem is connected ?
at!gstatus?
!GSTATUS:
Current Time: 890 Temperature: 41
Reset Counter: 2 Mode: ONLINE
LTE band: B7 LTE bw: 20 MHz
LTE Rx chan: 3000 LTE Tx chan: 24400
LTE CA state: NOT ASSIGNED
RRC state: RRC Idle
IMS reg state: No Srv
PCC RxM RSSI: -76 RSRP (dBm): -105
PCC RxD RSSI: -95 RSRP (dBm): -136
Tx Power: 0 TAC: 08C3 (2243)
RSRQ (dB): -9.5 Cell ID: 00996A01 (10054145)
SINR (dB): 7.0
at+creg
at+creg?
+CREG: 0,1
at!scact?
!SCACT: 1,0
at!scact=1
+CME ERROR: no network service
at!gobiimpref?
!GOBIIMPREF:
preferred fw version: 02.20.03.00
preferred config name: GENERIC_002.017_000
current fw version: 02.20.03.00
current carrier name: GENERIC
current config name: GENERIC_002.017_000
I have the logs (syslog) from my debian 8 (3.16.0-7-amd64) :
May 24 09:29:13 systemd[1]: Starting mobile data connection...
May 24 09:29:13 systemd[1]: Started mobile data connection.
May 24 09:29:13 pppd[1458]: pppd 2.4.6 started by root, uid 0
May 24 09:29:14 chat[1460]: timeout set to 10 seconds
May 24 09:29:14 chat[1460]: abort on (BUSY)
May 24 09:29:14 chat[1460]: abort on (NO CARRIER)
May 24 09:29:14 chat[1460]: abort on (VOICE)
May 24 09:29:14 chat[1460]: abort on (NO DIALTONE)
May 24 09:29:14 chat[1460]: abort on (NO DIAL TONE)
May 24 09:29:14 chat[1460]: abort on (NO ANSWER)
May 24 09:29:14 chat[1460]: abort on (DELAYED)
May 24 09:29:14 chat[1460]: send (ATZ^M)
May 24 09:29:14 chat[1460]: timeout set to 20 seconds
May 24 09:29:14 chat[1460]: expect (OK)
May 24 09:29:14 chat[1460]: ATZ^M^M
May 24 09:29:14 chat[1460]: OK
May 24 09:29:14 chat[1460]: -- got it
May 24 09:29:14 chat[1460]: send (\d\d\d\d\d\d\d\d\d\d\d\d\d\d\d\d\d\d\dAT+CGDCONT=1,"IP","orange-mib"^M)
May 24 09:29:33 chat[1460]: expect (OK)
May 24 09:29:33 chat[1460]: ^M
May 24 09:29:33 chat[1460]: AT+CGDCONT=1,"IP","orange-mib"^M^M
May 24 09:29:33 chat[1460]: OK
May 24 09:29:33 chat[1460]: -- got it
May 24 09:29:33 chat[1460]: send (AT!IMPREF="GENERIC"^M)
May 24 09:29:34 chat[1460]: expect (OK)
May 24 09:29:34 chat[1460]: ^M
May 24 09:29:34 chat[1460]: AT!IMPREF="GENERIC"^M^M
May 24 09:29:34 chat[1460]: OK
May 24 09:29:34 chat[1460]: -- got it
May 24 09:29:34 chat[1460]: send (ATDT*99#\\^M)
May 24 09:29:34 chat[1460]: expect (CONNECT)
May 24 09:29:34 chat[1460]: ATDT*99#\^M^M
May 24 09:29:34 chat[1460]: CONNECT
May 24 09:29:34 chat[1460]: send (^M)
May 24 09:29:34 pppd[1458]: Script /usr/sbin/chat -vf /etc/ppp/peers/operateur3g.chat finished (pid 1459), status = 0x0
May 24 09:29:34 pppd[1458]: Serial connection established.
May 24 09:29:34 pppd[1458]: using channel 2
May 24 09:29:34 pppd[1458]: Using interface ppp0
May 24 09:29:34 pppd[1458]: Connect: ppp0 <--> /dev/modem_3g
May 24 09:29:35 pppd[1458]: sent [LCP ConfReq id=0x1 <asyncmap 0x20a0000> <magic 0x3d16ffcd> <pcomp> <accomp>]
May 24 09:29:35 pppd[1458]: rcvd [LCP ConfReq id=0x0 <asyncmap 0x0> <auth chap MD5> <magic 0x5b4193a9> <pcomp> <accomp>]
May 24 09:29:35 pppd[1458]: sent [LCP ConfNak id=0x0 <auth pap>]
May 24 09:29:35 pppd[1458]: rcvd [LCP ConfAck id=0x1 <asyncmap 0x20a0000> <magic 0x3d16ffcd> <pcomp> <accomp>]
May 24 09:29:35 pppd[1458]: rcvd [LCP ConfReq id=0x1 <asyncmap 0x0> <auth pap> <magic 0x5b4193a9> <pcomp> <accomp>]
May 24 09:29:35 pppd[1458]: sent [LCP ConfAck id=0x1 <asyncmap 0x0> <auth pap> <magic 0x5b4193a9> <pcomp> <accomp>]
May 24 09:29:35 pppd[1458]: sent [LCP EchoReq id=0x0 magic=0x3d16ffcd]
May 24 09:29:35 pppd[1458]: sent [PAP AuthReq id=0x1 user="" password=<hidden>]
May 24 09:29:35 pppd[1458]: rcvd [LCP DiscReq id=0x2 magic=0x5b4193a9]
May 24 09:29:35 pppd[1458]: rcvd [LCP EchoRep id=0x0 magic=0x5b4193a9 3d 16 ff cd]
May 24 09:29:35 pppd[1458]: rcvd [PAP AuthAck id=0x1 ""]
May 24 09:29:35 pppd[1458]: PAP authentication succeeded
May 24 09:29:35 pppd[1458]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
May 24 09:29:35 pppd[1458]: rcvd [IPCP ConfReq id=0x0]
May 24 09:29:35 pppd[1458]: sent [IPCP ConfNak id=0x0 <addr 0.0.0.0>]
May 24 09:29:35 pppd[1458]: rcvd [IPCP ConfNak id=0x1 <addr 10.65.233.100> <ms-dns1 192.168.10.110> <ms-dns2 194.51.3.56>]
May 24 09:29:35 pppd[1458]: sent [IPCP ConfReq id=0x2 <addr 10.65.233.100> <ms-dns1 192.168.10.110> <ms-dns2 194.51.3.56>]
May 24 09:29:35 pppd[1458]: rcvd [IPCP ConfReq id=0x1]
May 24 09:29:35 pppd[1458]: sent [IPCP ConfAck id=0x1]
May 24 09:29:35 pppd[1458]: rcvd [IPCP ConfAck id=0x2 <addr 10.65.233.100> <ms-dns1 192.168.10.110> <ms-dns2 194.51.3.56>]
May 24 09:29:35 pppd[1458]: Could not determine remote IP address: defaulting to 10.64.64.64
May 24 09:29:35 pppd[1458]: replacing old default route to eth1 [192.168.1.1]
May 24 09:29:35 pppd[1458]: local IP address 10.65.233.100
May 24 09:29:35 pppd[1458]: remote IP address 10.64.64.64
May 24 09:29:35 pppd[1458]: primary DNS address 192.168.10.110
May 24 09:29:35 pppd[1458]: secondary DNS address 194.51.3.56
May 24 09:29:35 pppd[1458]: Script /etc/ppp/ip-up started (pid 1484)
May 24 09:29:35 pppd[1458]: Script /etc/ppp/ip-up finished (pid 1484), status = 0x0
May 24 09:29:37 ntpd[687]: Listen normally on 8 ppp0 10.65.233.100 UDP 123
May 24 09:29:37 ntpd[687]: 91.121.7.182 interface 192.168.1.29 -> 10.65.233.100
May 24 09:29:37 ntpd[687]: 62.210.244.146 interface 192.168.1.29 -> 10.65.233.100
May 24 09:29:37 ntpd[687]: 137.74.28.231 interface 192.168.1.29 -> 10.65.233.100
May 24 09:29:37 ntpd[687]: 92.243.6.5 interface 192.168.1.29 -> 10.65.233.100
May 24 09:29:37 ntpd[687]: peers refreshed
May 24 09:30:05 pppd[1458]: sent [LCP EchoReq id=0x1 magic=0x3d16ffcd]
May 24 09:30:35 pppd[1458]: sent [LCP EchoReq id=0x2 magic=0x3d16ffcd]
May 24 09:31:05 pppd[1458]: sent [LCP EchoReq id=0x3 magic=0x3d16ffcd]
May 24 09:31:35 pppd[1458]: sent [LCP EchoReq id=0x4 magic=0x3d16ffcd]
May 24 09:32:05 pppd[1458]: No response to 4 echo-requests
May 24 09:32:05 pppd[1458]: Serial link appears to be disconnected.
May 24 09:32:05 pppd[1458]: Connect time 2.5 minutes.
May 24 09:32:05 pppd[1458]: Sent 1986 bytes, received 879 bytes.
May 24 09:32:05 pppd[1458]: restoring old default route to eth1 [192.168.1.1]
May 24 09:32:05 pppd[1458]: Script /etc/ppp/ip-down started (pid 1544)
May 24 09:32:05 pppd[1458]: sent [LCP TermReq id=0x2 "Peer not responding"]
May 24 09:32:05 pppd[1458]: Script /etc/ppp/ip-down finished (pid 1544), status = 0x0
May 24 09:32:07 ntpd[687]: Deleting interface #8 ppp0, 10.65.233.100#123, interface stats: received=1, sent=15, dropped=0, active_time=150 secs
May 24 09:32:07 ntpd[687]: 92.243.6.5 interface 10.65.233.100 -> (none)
May 24 09:32:07 ntpd[687]: 137.74.28.231 interface 10.65.233.100 -> (none)
May 24 09:32:07 ntpd[687]: 62.210.244.146 interface 10.65.233.100 -> (none)
May 24 09:32:07 ntpd[687]: 91.121.7.182 interface 10.65.233.100 -> (none)
May 24 09:32:07 ntpd[687]: peers refreshed
May 24 09:32:08 pppd[1458]: sent [LCP TermReq id=0x3 "Peer not responding"]
May 24 09:32:11 pppd[1458]: Connection terminated.
May 24 09:32:12 pppd[1458]: Modem hangup
May 24 09:32:12 pppd[1458]: Exit.
May 24 09:32:12 systemd[1]: mobiledata.service: main process exited, code=exited, status=16/n/a
May 24 09:32:12 poff[1581]: /usr/bin/poff: No pppd is running. None stopped.
root@host:~# route
Table de routage IP du noyau
Destination Passerelle Genmask Indic Metric Ref Use Iface
default * 0.0.0.0 U 0 0 0 ppp0
10.64.64.64 * 255.255.255.255 UH 0 0 0 ppp0
192.168.0.0 * 255.255.255.0 U 0 0 0 eth0
192.168.1.0 * 255.255.255.0 U 0 0 0 eth1
root@host:~# ip a
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether d0:4c:c1:03:0d:b0 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.29/24 brd 192.168.1.255 scope global eth1
valid_lft forever preferred_lft forever
inet6 fe80::d24c:c1ff:fe03:db0/64 scope link
7: wwan0: <BROADCAST,MULTICAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether f2:6b:23:e1:48:dc brd ff:ff:ff:ff:ff:ff
8: ppp0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 3
link/ppp
inet 10.65.233.100 peer 10.64.64.64/32 scope global ppp0
And sorry, but I don’t understand what means this sentence : “then establish the session use at!scact=1 (we also have QMI - checkout the QMI SDK or SDKlite) on the host site call a dhcp client to transfer the IP address ( dhclinet)”
Thanks again !
