one of our BX3105 boards is not responding to AT commands given via the terminal. After pushing the board’s RESET button it doesn’t say ‘READY’, instead it says:
No you use this jumper to put it into boot mode for a firmware update which would mean it does not respond to AT commands. If its not connected don’t connect it now.
Are there any differences between the working and non working boards that you are aware of? Otherwise go for a firmware download to see if this brings it back/resets something that was causing a problem.
We’re not aware of any differences between our boards.
I downloaded the latest firmware version (2.5.0) to the device - apparently it was successful (‘completed with 0’) - but with ‘-v’ it still says ‘BC310x bootloader version V1.0’…
I also tried the old version 1.0.0 but the board is still not answering to AT commands
