for my application, I use my own webserver implementation (works find with other tcp/ip chips), since later we have not only the BX3105 as network interface and the webserver must use all network interfaces. Therefore, I cannot use the BX3105 internal HTTP host.
I have 3 problems with this:
- I cannot use Port 80 for my own purpose, even when not using the chips internal HTTP server.
- Whenever I try to access port 80 from a browser I get a login page with SSID and Password, even when I only use the station mode.
- My biggest problem: The BX3105 stops responding sometimes while I handle multiple sockets. My browser opens multiple connections to the module on Port 8080. I handle the HTTP request on each socket and afterwards the socket is closed. But it might happen that I get no response when closing a socket. I receive incoming connections and incoming data but no responses for my commands, as seen below. The Data with COM29 is sent, the Data with COM2 is received.
09:19:58.479 COM29> AT+KTCPSND=2,\0d\0a\09\09\09\09\3c\2fdiv\3e\0d\0a\09\09\09\3c\2fdiv\3e\0d\0a\09\09\3c\2fdiv\3e\0d\0a\09\3c\2fcenter\3e\0d\0a\3c\2fbody\3e\0d\0a\3c\2fhtml\3e\0d\0a
09:19:58.490 COM2>
09:19:58.490 COM2> OK
09:19:58.492 COM29> AT+KTCPCLOSE=2,1
09:19:58.594 COM2>
09:19:58.596 COM2> +KTCP_SRVREQ: 1,3,“192.168.178.54”,32753
09:19:58.596 COM2>
09:19:58.596 COM2> +KTCP_DATA: 3,331,GET /main.css HTTP/1.1
09:19:58.598 COM2> Host: 192.168.178.87:8080
09:19:58.600 COM2> User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:65.0) Gecko/20100101 Firefox/65.0
09:19:58.600 COM2> Accept: text/css,/;q=0.1
09:19:58.600 COM2> Accept-Language: de-DE,de;q=0.8,en-US;q=0.5,en;q=0.3
09:19:58.602 COM2> Accept-Encoding: gzip, deflate
09:19:58.602 COM2> DNT: 1
09:19:58.602 COM2> Connection: keep-alive
09:19:58.602 COM2>
09:19:58.602 COM2>
09:19:58.622 COM2>
09:19:58.624 COM2> +KTCP_SRVREQ: 1,4,“192.168.178.54”,32756
09:19:58.624 COM2>
09:19:58.624 COM2> +KTCP_DATA: 4,315,GET /script.js HTTP/1.1
09:19:58.626 COM2> Host: 192.168.178.87:8080
09:19:58.628 COM2> User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:65.0) Gecko/20100101 Firefox/65.0
09:19:58.628 COM2> Accept: /
09:19:58.628 COM2> Accept-Language: de-DE,de;q=0.8,en-US;q=0.5,en;q=0.3
09:19:58.630 COM2> Accept-Encoding: gzip, deflate
09:19:58.630 COM2> DNT: 1
09:19:58.630 COM2> Connection: keep-alive
09:19:58.630 COM2>
09:19:58.630 COM2>
09:19:58.851 COM2>
09:19:58.853 COM2> +KTCP_SRVREQ: 1,5,“192.168.178.54”,32757
09:19:58.853 COM2>
09:19:58.853 COM2> +KTCP_DATA: 5,315,GET /string.js HTTP/1.1
09:19:58.855 COM2> Host: 192.168.178.87:8080
09:19:58.857 COM2> User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:65.0) Gecko/20100101 Firefox/65.0
09:19:58.857 COM2> Accept: /
09:19:58.857 COM2> Accept-Language: de-DE,de;q=0.8,en-US;q=0.5,en;q=0.3
09:19:58.859 COM2> Accept-Encoding: gzip, deflate
09:19:58.859 COM2> DNT: 1
09:19:58.859 COM2> Connection: keep-alive
09:19:58.859 COM2>
09:19:58.859 COM2>
09:20:01.585 COM2>
09:20:01.586 COM2> +KTCP_SRVREQ: 1,6,“192.168.178.54”,32755
09:20:06.573 COM29> AT+KTCPCLOSE=2,1
09:20:07.581 COM2>
09:20:07.582 COM2> +KTCP_NOTIF: 6,4
09:20:12.577 COM29> AT+KTCPCLOSE=2,1
I hope someone can help me here.
EDIT: It seems to happen only when KTCPCLOSE is sent too early after KTCP_SEND. The at reference stated, that the system must be rebooted when KTCPCLOSE=session,1 is used on a server socket. Is this also the case for sockets that were gained from a server socket via +KTCPSERVREQ? If I wait manually for 100ms it does not happen often, like before.
My firmware revision is R1.3.0.201816011422.BX310x_1 with a bootloader version 1.0. A firmware update with firmware updater v2 to version 2.5.0 did not work. Since I did not find any full version change list, I do not know if this is an error, that is already fixed in later revisions.
Best regards,
Tim Koczwara
