Hi all,
I am trying to write data to the I2C. The adl_buswrite returns success but there is no data sent on the bus. Meanwhile when i try to read data, i am able to get the data.
Could anyone kindly help me in sorting out the problem.
#include "adl_global.h"
/* Mandatory variables */
/* wm_apmCustomStackSize */
const u16 wm_apmCustomStackSize = 1024;
s32 I2C_ADS112_Handle;
static adl_tmr_t *ADC_Tmr;
adl_busAccess_t iicBus_Access = { 0, 0 };
u32 I2C_ADS112_Init ( void );
void ADC_Handler(u8 id,void *Context);
void Write_Data(u8 x);
void Read_Value(u8 id,void *Context);
/* Function : adl_main */
void adl_main(adl_InitType_e adlInitType)
adl_atSendResponse(ADL_AT_RSP,"\r\n I2C Testing\r\n");
if ( I2C_ADS112_Init() ){
adl_atSendResponse(ADL_AT_RSP,"\r\n I2C Subscribed\r\n");
ADC_Tmr=adl_tmrSubscribe(TRUE,100,ADL_TMR_TYPE_100MS,ADC_Handler);
else{
adl_atSendResponse(ADL_AT_RSP,"\r\n I2C Subscribe Failed\r\n");
/* Function : I2C_ADS112_Init */
u32 length = 8;
adl_busI2CSettings_t I2CSettings = {
(0x90>>1), // ChipAddress
ADL_BUS_I2C_CLK_FAST, // Clk_Speed
ADL_BUS_I2C_ADDR_7_BITS,
ADL_BUS_I2C_MASTER_MODE
/* Open I2C bus */
I2C_ADS112_Handle = adl_busSubscribe (
ADL_BUS_I2C,
1,
&I2CSettings );
adl_busIOCtl(I2C_ADS112_Handle, ADL_BUS_CMD_SET_ADD_SIZE, &length);
return I2C_ADS112_Handle;
/* Function : ADC_Handler */
/* Object : This timer is used to read the ADC Values */
/* every 10 Seconds to Server */
u8 Data;
Data=0x01;
Write_Data(Data);
Data=0xC1;
Write_Data(Data);
Data=0xE0;
Write_Data(Data);
/*Place the settings info in the Low Thresh-hold Register*/
Data=0x02;
Write_Data(Data);
Data=0x00;
Write_Data(Data);
Data=0x00;
Write_Data(Data);
/*Place the settings info in the High Thresh-hold Register*/
Data=0x03;
Write_Data(Data);
Data=0xFF;
Write_Data(Data);
Data=0xFF;
Write_Data(Data);
adl_tmrSubscribe(FALSE,20,ADL_TMR_TYPE_100MS,Read_Value);
/* Function : Write_Data */
/* Object : Writes the data to the I2C Bus */
u8 data;
data = x;
iicBus_Access.Address = ((u32)0x90)<<24;
if(adl_busWrite(I2C_ADS112_Handle,&iicBus_Access,1,(void*)&data)==OK){
//Do Nothing
}else{
adl_atSendResponse(ADL_AT_RSP,"\r\n Write Error\n");
/* Function : Read_Value */
/* Object : Reads Value from a register */
u16 Register_Val=0;
char Values[2];
u8 Data;
Data = 0x02;
adl_atSendResponse(ADL_AT_RSP,"\r\n Going to Read\r\n");
Write_Data(Data);
char Sting_Val[10];
iicBus_Access.Address = ((u32)0x91)<<24;
//iicBus_Access.Address |= 0x80000000;
if(adl_busRead(I2C_ADS112_Handle,&iicBus_Access,2,(void*)&Register_Val)==OK){
Values[1]=(Register_Val & 0xFF);
Values[0]=(Register_Val>>8);
wm_sprintf(Sting_Val,"%x%x",Values[1],Values[0]);
//adl_atSendResponse(ADL_AT_RSP,"\r\n Read1 Success\r\n");
adl_atSendResponse(ADL_AT_RSP,Sting_Val);
}else{
adl_atSendResponse(ADL_AT_RSP,"\r\n Read Error\n");
Thanks & Regards,
Rajamanickem. S
