BC127 Analog audio configration
BT_VOL_CONFIG=<default_hfp_volume> <default_a2dp_volume> <a2dp_volume_steps>
<volume_scaling_method>
Where does the parameter <default_hfp_volume> affect?
A. Audio Input(Mic)
B. Audio Output(Speaker)
C. Both
Best Regards,
Chikyoung
Hi @cksung,
It looks like any device connects to the BC module, the volume gets set to whatever default value is in the BT_VOL_CONFIG so <default_hfp_volume> might affect both. I don’t get the relevant information in BC127 document so if you need more detail please contact your reseller or distributor directly for technical support
It seems only affects the speaker volume value, the mic volume is not changed.
