This is for those trying to use C++ in the Legato environment.
I’ve just found that the adef parser doesn’t like C++ files (i.e. files with the extensions .cc or .cpp) when configuring the project executables. This was a problem for me as the application I’m porting across to the Legato is based around a C++ class that contains all the application logic.
I did find a workaround:
I turned my application into a static library (using a separate DS3 project - note the bug in DS3 that doesn’t let you create a 'static library project - create a normal C++ project then change the Target type after creation). I also removed the code for ‘main()’ from my library.
Inside my library, I wrote a ‘factory’ function to instantiate my class and return a void pointer to it. I also wrote wrapper functions for the class public member functions so that they could be called from C. Finally, I wrapped the appropriate functions in 'extern “C” {} ’ so that the names wouldn’t be mangled by the compilers and linker.
I then turned main() into the Legato ‘main()’ - using COMPONENT_INIT { } and referencing my application class via the wrapper functions in the library.
Finally, I added both my static library AND the yocto stdlib++ static library to my adef definitions like so:executables:
MyApp ( "legato_main.c"
"libMyAppLib.a"
"/opt/swi/y14-ext/tmp/sysroots/swi-mdm9x15/usr/lib/libm.a"
"/opt/swi/y14-ext/tmp/sysroots/swi-mdm9x15/usr/lib/libstdc++.a"
"/opt/swi/y14-ext/tmp/sysroots/swi-mdm9x15/usr/lib/libz.a"
and all is sweet
Note that I had to use the full path to the cross-compiler system libs … the adef parser can’t find them otherwise.
Adding both of these would be a good idea. Building an environment variable at runtime sure beats hardcoding paths!
For me, getting C++ support in the adef files is probably slightly more important/useful than the environment variable (I can live with the hardcoded paths).
Out of curisoity, what revision of C++ are you using? Are you using C++11?
One of the things we’re thinking of doing is adding a C++11 compatablity header to add support for creating C++ objects using memory pools and enable use of lambdas as callbacks. Among other things.
I don’t have a timeline on this, but since you are already using C++ some real world info would be really helpful.
Thanks for pushing the envelope and trying new things. We plan to do C++ support, but haven’t got around to it yet. (So much to do!) Your input on this is a big help.
The ‘mk’ tools (mkexe, mkapp) detect the source code language based on the file name extension. That’s missing the checks for the various C++ file name extensions.
I think we should be able to fix this fairly easily. We’ll look into it.
We’re not using any of the fancy bits of C++ - just using it to provide enforced object orientation and encapulation of data where it is required - mostly around protocol state machine handling and I/O devices.
Whoa! Way over my head here! I’m a hardware engineer that programs - not a programmer that does hardware… although I guess I need to learn some more.
No probs. As we find things I’ll keep feeding them up to the forum.
It’s exciting to be working on this stuff - I like to push it hard and It’s nice that you guys are so responsive when I hit a wall. There’s always plenty to do …
Sounds like an easy fix. Well, easy to talk about anyway.
Jen and I took a look at this. Like Jen said, the mktools were rejecting the C++ because of it’s extension.
I’ve also modified the tools to automaticly pull in the C++ standard lib. And I added some extern “C” definitions to the header files. So the result of this is that it will be easer to use C++ in Legato, for example, yet another hello world, but now in C++:
WOW! That’s quick work! Look forward to getting the next release.
No problems - if I find more, I’ll let you know.
One question - while you’re working on this, can you make the adef parser manage C++ files with the .cc extension as well as .cpp? I’m test porting code from other platforms to the Legato, and a lot of the code has .cc as the file extension. GCC doesn’t really care - it processes .cc as C++ by default.
I’m trying to implement a small C++ sample but get the following error when building the app:
mkapp -t wp76xx helloCPP.adef
[1/1] Regenerating build script
[3/9] Compiling C++ source
FAILED: _build_helloCPP/wp76xx/component/b130cd0656327c8de99a44179d5831dc/obj/4c01286321aa8b611d1cea84c8618f67.o
/home/mangoh/workspace/leaf-data/wp76stable/wp76-toolchain/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-g++ --sysroot=/home/mangoh/workspace/leaf-data/wp76stable/wp76-toolchain/sysroots/armv7a-neon-poky-linux-gnueabi -MMD -MF _build_helloCPP/wp76xx/component/b130cd0656327c8de99a44179d5831dc/obj/4c01286321aa8b611d1cea84c8618f67.o.d -c /home/mangoh/workspace/leaf-data/wp76stable/fx30-cat1-legato/apps/helloCPP/helloCPPComponent/helloCPP.cpp -o _build_helloCPP/wp76xx/component/b130cd0656327c8de99a44179d5831dc/obj/4c01286321aa8b611d1cea84c8618f67.o -DLE_FILENAME=basename /home/mangoh/workspace/leaf-data/wp76stable/fx30-cat1-legato/apps/helloCPP/helloCPPComponent/helloCPP.cpp -Wall -fPIC -Werror -fvisibility=hidden -DMK_TOOLS_BUILD -DLEGATO_EMBEDDED -I ./_build_helloCPP/wp76xx -I/home/mangoh/workspace/leaf-data/wp76stable/fx30-cat1-legato/interfaces -I/home/mangoh/workspace/leaf-data/wp76stable/fx30-cat1-legato/framework/include -I/home/mangoh/workspace/leaf-data/wp76stable/fx30-cat1-legato/apps/helloCPP -I./_build_helloCPP/wp76xx/component/b130cd0656327c8de99a44179d5831dc/src -DLE_COMPONENT_NAME=helloCPPComponent -DLE_LOG_SESSION=helloCPPComponent_LogSession -DLE_LOG_LEVEL_FILTER_PTR=helloCPPComponent_LogLevelFilterPtr “-DCOMPONENT_INIT=LE_CI_LINKAGE LE_SHARED void _helloCPPComponent_COMPONENT_INIT()”
:0:16: error: ‘LE_CI_LINKAGE’ does not name a type; did you mean ‘LE_FILENAME’?
/home/mangoh/workspace/leaf-data/wp76stable/fx30-cat1-legato/apps/helloCPP/helloCPPComponent/helloCPP.cpp:7:1: note: in expansion of macro ‘COMPONENT_INIT’
COMPONENT_INIT{
/home/mangoh/workspace/leaf-data/wp76stable/fx30-cat1-legato/apps/helloCPP/helloCPPComponent/helloCPP.cpp: In function ‘int greet()’:
/home/mangoh/workspace/leaf-data/wp76stable/fx30-cat1-legato/apps/helloCPP/helloCPPComponent/helloCPP.cpp:11:5: error: ambiguating new declaration of ‘int greet()’
int greet() {
/home/mangoh/workspace/leaf-data/wp76stable/fx30-cat1-legato/apps/helloCPP/helloCPPComponent/helloCPP.cpp:5:6: note: old declaration ‘void greet()’
void greet(void);
/home/mangoh/workspace/leaf-data/wp76stable/fx30-cat1-legato/apps/helloCPP/helloCPPComponent/helloCPP.cpp:14:1: error: no return statement in function returning non-void [-Werror=return-type]
cc1plus: all warnings being treated as errors
