Hy all
I have some serious problems width the usable compilers .
1. I have a development phase code for q2687 . Some part of these code is working fine on R72 already . But i try on R73 because i have an another problem with R72 , but not
working . Exactly the parallel bus is not working , not any error code or simillar , look like everithing working fine but no any output on parallel bus . The code not changed .
2. The oroginal problem with the R72 is a programing problem . I use Pointer type structures with pointer type elements and with the GCC compiler i look a mistic problem .
These struct pointers sometimes loose the correct value or damaged the contents returned . I dont know why ? I want to try on R73 but i get the point 1 problem . The
problematic code section not countinous any special ADL command only C code . I try on visual C and work fine . I use these code on another MCU and already works fine .
I try the packed structure mode in GCC but not too good resolve for the problem .
PUBLIC struct SD_FileType
u8 *Name;
u8 *Ext;
u32 dSize;
u32 dDataAddress;
u32 dPtr;
u8 bMode;
u8 bAttr;
u16 wDate;
} sSD_FileHolterMem , sSD_FileDeviceDat , sSD_FileStatusDat , sSD_FilePatientDat , sSD_FileFirmwareBin , sSD_FileRecLngthDat , sSD_FileAutorunInf ,sSD_FileHolterIco ;
3. I want to try ADS compiler (ADS DEVS 1.2 ) what i cheking the code on a another compiler but i get new another problems . The ADS compiler compile the code witout any
error code but the downloaded file alway restart the module . I debug when brokedown the program :
local_ret = adl_busIOCtl ( local_handle , ADL_BUS_CMD_SET_PARALLEL_CFG , &local_setting ); These line is the problematic .
But the problem in point 2 is not present in ADS .
I comment out these line but the parallel bus not working on R72 and R73 with ADS .
With GCC on R72 the bus and other work fine but have a pointer problem . On R73 GCC and ADS the PBUS not working . On R72 and R73 width ADS Pbus not working .
ehh and finally with M2M (GCC new version) width R72 the SPI bus not working , and width R73 the Pbus also not working .
Please help what is the best compiler for open AT ? :smiley:
