Thanks for your reply.
As far as your second problem goes, you can try sending your data as a byte array instead of a string.
I tried this with the following syntax:
HANDLER SpiReceptionHandler
Event spi_event_type,
uint8 msg [MSG_MAX_LEN] IN,
uint16 msgLen IN
However the api parser doesn’t allow to use an array of uint8 in the handler (there isn’t a parsing error if it’s in a function).
Did I misunderstood something concerning the syntax to define a byte array ?
Best regards,
