Hello.
We use Sierra production in gas\oil automatization with thousands pcs.
Many time we used a bundle: Mikrtotik RB750UP + SIerra SL8082. All works fine. But recently we knows that SL8082, SL8083 production will stop. I try SL8082T as alternative, but now we fail to use RB750UP + SIerra SL8082T.
I contact with Mikrotik support, but they link to Sierra support.
Now i have next situation: Mikrotik successfull connect to network, get true ip address, dns servers, but any user data dropped. I see that data transfered to network, but no answer. On identical configuration with SL8082 all works good, so it’s not a Mikrotik firewall problem.
I can provide remote access (ssh) to Mikrotik device with SL8082T connected.
I think that reasonably engage Mikrotik tech support specialist into this thread.
Thanks.
Mikrotik connection log with SL8082T:
Jan/02/1970 00:00:19 route,debug,calc End calculation
Jan/02/1970 00:00:19 route,debug End redistribution
Jan/02/1970 00:00:20 async,debug usb1:3: sent ATH
Jan/02/1970 00:00:20 async,debug usb1:3: rcvd OK
Jan/02/1970 00:00:20 async,ppp,info ppp-out1: initializing modem…
Jan/02/1970 00:00:21 async,ppp,info ppp-out1: dialing out…
Jan/02/1970 00:00:21 async,debug usb1:3: sent AT+CGDCONT=1,“IP”,“paramapn54.ural”
Jan/02/1970 00:00:21 async,debug usb1:3: rcvd OK
Jan/02/1970 00:00:21 async,debug usb1:3: sent ATDT99**1#
Jan/02/1970 00:00:21 async,debug usb1:3: rcvd CONNECT 115200
Jan/02/1970 00:00:21 async,ppp,debug ppp-out1: LCP lowerup
Jan/02/1970 00:00:21 async,ppp,debug ppp-out1: LCP open
Jan/02/1970 00:00:21 async,ppp,debug,packet ppp-out1: sent LCP ConfReq id=0x1
Jan/02/1970 00:00:21 async,ppp,debug,packet <magic 0x3bc4981a>
Jan/02/1970 00:00:21 async,ppp,debug,packet <mrru 1600>
Jan/02/1970 00:00:21 async,ppp,debug,packet ppp-out1: rcvd LCP ConfRej id=0x1
Jan/02/1970 00:00:21 async,ppp,debug,packet ppp-out1: sent LCP ConfReq id=0x2
Jan/02/1970 00:00:21 async,ppp,debug,packet ppp-out1: rcvd LCP ConfAck id=0x2
Jan/02/1970 00:00:21 route,debug,event Interface change
Jan/02/1970 00:00:21 route,debug,event interface=ether5-slave-local
Jan/02/1970 00:00:21 route,debug,event status=UP,RUNNING
Jan/02/1970 00:00:21 route,debug,event mtu=1500
Jan/02/1970 00:00:22 async,ppp,debug ppp-out1: LCP timer
Jan/02/1970 00:00:22 async,ppp,debug,packet ppp-out1: sent LCP ConfReq id=0x3
Jan/02/1970 00:00:22 async,ppp,debug,packet <magic 0x3bc4981a>
Jan/02/1970 00:00:22 async,ppp,debug,packet ppp-out1: rcvd LCP ConfAck id=0x3
Jan/02/1970 00:00:24 async,ppp,debug ppp-out1: LCP timer
Jan/02/1970 00:00:24 async,ppp,debug,packet ppp-out1: sent LCP ConfReq id=0x4
Jan/02/1970 00:00:24 async,ppp,debug,packet <magic 0x3bc4981a>
Jan/02/1970 00:00:24 async,ppp,debug,packet ppp-out1: rcvd LCP ConfAck id=0x4
Jan/02/1970 00:00:24 async,ppp,debug,packet ppp-out1: rcvd LCP ConfReq id=0x1
Jan/02/1970 00:00:24 async,ppp,debug,packet <mru 1500>
Jan/02/1970 00:00:24 async,ppp,debug,packet <asyncmap 0x0>
Jan/02/1970 00:00:24 async,ppp,debug,packet <magic 0x69eb6f31>
Jan/02/1970 00:00:24 async,ppp,debug,packet ppp-out1: sent LCP ConfAck id=0x1
Jan/02/1970 00:00:24 async,ppp,debug ppp-out1: LCP opened
Jan/02/1970 00:00:24 async,ppp,debug,packet ppp-out1: sent PAP AuthReq id=0x1
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: rcvd PAP AuthAck id=0x1
Jan/02/1970 00:00:27 async,ppp,debug,packet Welcome!
Jan/02/1970 00:00:27 async,ppp,info ppp-out1: authenticated
Jan/02/1970 00:00:27 async,ppp,debug ppp-out1: IPCP lowerup
Jan/02/1970 00:00:27 async,ppp,debug ppp-out1: IPCP open
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: sent IPCP ConfReq id=0x1
Jan/02/1970 00:00:27 async,ppp,debug,packet <addr 0.0.0.0>
Jan/02/1970 00:00:27 async,ppp,debug,packet <ms-dns 0.0.0.0>
Jan/02/1970 00:00:27 async,ppp,debug ppp-out1: IPV6CP open
Jan/02/1970 00:00:27 async,ppp,debug ppp-out1: MPLSCP lowerup
Jan/02/1970 00:00:27 async,ppp,debug ppp-out1: MPLSCP open
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: sent MPLSCP ConfReq id=0x1
Jan/02/1970 00:00:27 async,ppp,debug ppp-out1: BCP open
Jan/02/1970 00:00:27 async,ppp,debug ppp-out1: CCP lowerup
Jan/02/1970 00:00:27 async,ppp,debug ppp-out1: CCP open
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: rcvd IPCP ConfReq id=0x1
Jan/02/1970 00:00:27 async,ppp,debug,packet <addr 192.168.111.111>
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: sent IPCP ConfAck id=0x1
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: rcvd IPCP ConfRej id=0x1
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: sent IPCP ConfReq id=0x2
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: rcvd LCP ProtRej id=0xf
Jan/02/1970 00:00:27 async,ppp,debug,packet 82 81 01 01 00 04
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: rcvd IPCP ConfNak id=0x2
Jan/02/1970 00:00:27 async,ppp,debug,packet <addr 192.168.1.2>
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: sent IPCP ConfReq id=0x3
Jan/02/1970 00:00:27 async,ppp,debug,packet ppp-out1: rcvd IPCP ConfAck id=0x3
Jan/02/1970 00:00:27 async,ppp,debug ppp-out1: IPCP opened
Jan/02/1970 00:00:27 async,ppp,info ppp-out1: connected
Jan/02/1970 00:00:27 route,debug,event Interface change
Jan/02/1970 00:00:27 route,debug,event interface=ppp-out1
Jan/02/1970 00:00:27 route,debug,event status=UP,RUNNING
Jan/02/1970 00:00:27 route,debug,event mtu=1500
Jan/02/1970 00:00:27 route,debug,calc Begin calculation
Jan/02/1970 00:00:27 route,debug,event Link up
Jan/02/1970 00:00:27 route,debug,event Update
Jan/02/1970 00:00:27 route,debug,event Added candidate route
Jan/02/1970 00:00:27 route,debug,event dst-prefix=0.0.0.0/0
Jan/02/1970 00:00:27 route,debug,event attributes
Jan/02/1970 00:00:27 route,debug,event protocol=DYNAMIC
Jan/02/1970 00:00:27 route,debug,event distance=1
Jan/02/1970 00:00:27 route,debug,event scope=30
Jan/02/1970 00:00:27 route,debug,event target-scope=10
Jan/02/1970 00:00:27 route,debug,event next-hop= address=192.168.111.111
Jan/02/1970 00:00:27 route,debug,event origin-type=DYNAMIC
Jan/02/1970 00:00:27 route,debug,calc End calculation
Jan/02/1970 00:00:27 route,debug Begin redistribution
Jan/02/1970 00:00:27 route,debug Accept 0.0.0.0/0
Jan/02/1970 00:00:27 route,debug Commit prefix 0.0.0.0/0
Jan/02/1970 00:00:27 route,debug End redistribution
Jan/02/1970 00:00:27 route,debug,event Address added or changed
Jan/02/1970 00:00:27 route,debug,event local=192.168.1.2
Jan/02/1970 00:00:27 route,debug,event network=192.168.111.111/32
Jan/02/1970 00:00:27 route,debug,event dst-prefix=192.168.111.111/32
Jan/02/1970 00:00:27 route,debug,event protocol=CONNECT
Jan/02/1970 00:00:27 route,debug,event distance=0
Jan/02/1970 00:00:27 route,debug,event scope=10
Jan/02/1970 00:00:27 route,debug,event target-scope=0
Jan/02/1970 00:00:27 route,debug,event connected-net= address=192.168.1.2/32 interface=ppp-out1
Jan/02/1970 00:00:27 route,debug,event routing-mark=main
Jan/02/1970 00:00:27 route,debug,event table=main
Jan/02/1970 00:00:27 route,debug,event origin-type=CONNECTED
Jan/02/1970 00:00:27 route,debug,calc Tag next hop for recalculation
Jan/02/1970 00:00:27 route,debug,calc address=192.168.111.111
Jan/02/1970 00:00:27 route,debug,calc Select route
Jan/02/1970 00:00:27 route,debug,calc dst-address=192.168.111.111/32
Jan/02/1970 00:00:27 route,debug,calc attributes
Jan/02/1970 00:00:27 route,debug,calc protocol=CONNECT
Jan/02/1970 00:00:27 route,debug,calc distance=0
Jan/02/1970 00:00:27 route,debug,calc scope=10
Jan/02/1970 00:00:27 route,debug,calc target-scope=0
Jan/02/1970 00:00:27 route,debug,calc connected-net= address=192.168.1.2/32 interface=ppp-out1
Jan/02/1970 00:00:27 route,debug,calc routing-mark=main
Jan/02/1970 00:00:27 route,debug,calc table=main
Jan/02/1970 00:00:27 route,debug,calc origin-type=CONNECTED
Jan/02/1970 00:00:27 route,debug,calc Next hop resolved
Jan/02/1970 00:00:27 route,debug,calc route=192.168.111.111/32
Jan/02/1970 00:00:27 route,debug,calc immediate-address=192.168.111.111
Jan/02/1970 00:00:27 route,debug,calc interface=ppp-out1
Jan/02/1970 00:00:27 route,debug,calc dst-address=0.0.0.0/0
Jan/02/1970 00:00:27 route,debug,calc protocol=DYNAMIC
Jan/02/1970 00:00:27 route,debug,calc distance=1
Jan/02/1970 00:00:27 route,debug,calc scope=30
Jan/02/1970 00:00:27 route,debug,calc target-scope=10
Jan/02/1970 00:00:27 route,debug,calc next-hop= address=192.168.111.111
Jan/02/1970 00:00:27 route,debug,calc origin-type=DYNAMIC
Jan/02/1970 00:00:27 route,debug Accept add 192.168.111.111/32
Jan/02/1970 00:00:27 route,debug Accept add 0.0.0.0/0
Jan/02/1970 00:00:27 route,debug Commit prefix 192.168.111.111/32
Jan/02/1970 00:00:54 async,ppp,debug,packet ppp-out1: sent LCP EchoReq id=0x0
Jan/02/1970 00:00:54 async,ppp,debug,packet <magic 0x3bc4981a>
Jan/02/1970 00:00:54 async,ppp,debug,packet ppp-out1: rcvd LCP EchoRep id=0x0
Jan/02/1970 00:00:54 async,ppp,debug,packet <magic 0x69eb6f31>
Jan/02/1970 00:01:24 async,ppp,debug,packet ppp-out1: sent LCP EchoReq id=0x1
Jan/02/1970 00:01:24 async,ppp,debug,packet <magic 0x3bc4981a>
Jan/02/1970 00:01:24 async,ppp,debug,packet ppp-out1: rcvd LCP EchoRep id=0x1
Jan/02/1970 00:01:24 async,ppp,debug,packet <magic 0x69eb6f31>
Jan/02/1970 00:01:54 async,ppp,debug,packet ppp-out1: sent LCP EchoReq id=0x2
Jan/02/1970 00:01:54 async,ppp,debug,packet <magic 0x3bc4981a>
Jan/02/1970 00:01:54 async,ppp,debug,packet ppp-out1: rcvd LCP EchoRep id=0x2
Jan/02/1970 00:01:54 async,ppp,debug,packet <magic 0x69eb6f31>
Jan/02/1970 00:02:24 async,ppp,debug,packet ppp-out1: sent LCP EchoReq id=0x3
Jan/02/1970 00:02:24 async,ppp,debug,packet <magic 0x3bc4981a>
Jan/02/1970 00:02:24 async,ppp,debug,packet ppp-out1: rcvd LCP EchoRep id=0x3
Jan/02/1970 00:02:24 async,ppp,debug,packet <magic 0x69eb6f31>
Jan/02/1970 00:02:54 async,ppp,debug,packet ppp-out1: sent LCP EchoReq id=0x4
Jan/02/1970 00:02:54 async,ppp,debug,packet <magic 0x3bc4981a>
Jan/02/1970 00:02:54 async,ppp,debug,packet ppp-out1: rcvd LCP EchoRep id=0x4
Jan/02/1970 00:02:54 async,ppp,debug,packet <magic 0x69eb6f31>
