I’ve added the BC127 to a project, and it seems that setting a NAME parameter longer than 19 or 20 (not sure, I want to use 21) characters bricks the unit. While the SHORT_NAME specifies 7 characters max, there is no mention of a maximum NAME length in the Melody documentation.
To recover the (rather expensive) units, is it possible to reflash the firmware from a non-responsive state?
This was found recently where there wasn’t a safe guard restricting the unit to 16 characters on the long name and fixed in a 6.1.8 RC build. We are going to perform a release this month with an official release for this.
To recover the unit you need to reflash it through the SPI interface using the Blueflash tool from the CSR bluesuite tool set, you also need to use the CSR SPI chip (as it is proprietary). If you don’t have access to SPI then there is no way to get it up and running through just the UART.
Thanks for the reply. Will the name be restricted to 16 characters by the module firmware? The factory default NAME is “BlueCreation-XXXXXX”, which is 19 characters. I would expect the allowed length to be at least this long.
Sorry my mistake, it was a different issue where a specific profile config bricked the unit. As per the manual I think the current firmware does allow you to set the name upto the 32 characters max as per the below.
config
AUDIO=0 0
AUDIO_ANALOG=15 15 1 OFF
AUDIO_DIGITAL=0 44100 64 100A00 OFF
AUTOCONN=0
AUTO_DATA=OFF OFF OFF
BALANCE=100 100
BATT_CONFIG=OFF 145 4250 1500 150
BLE_CONFIG=0 OFF 40 ON
BLE_CONN_PARAMS=128 12 6 40 0 400 50 400 400 61 400 400
BT_VOL_CONFIG=A A 10 1
CLASS_1=OFF
CMD_TO=20
COD=240404
CODEC=0 OFF
CONN_TO=0
DEEP_SLEEP=OFF
DISCOVERABLE=2 0
ENABLE_BATT_IND=ON
ENABLE_CAPSENSE=OFF
ENABLE_LED=ON
GPIO_CONFIG=ON 0 255
HFP_CONFIG=OFF ON OFF OFF OFF
HIGH_SPEED=OFF OFF
LOCAL_ADDR=20FABB075DD3
MAX_REC=2
MUSIC_META_DATA=OFF
MUSIC_OLD_AVRCP=OFF
NAME=BC-075DD3
NAME_SHORT=BC75DD3
PIN=0000
PROFILES=2 0 2 0 2 1 2 1 0 0 1 0
REMOTE_ADDR=000000000000
SSP_CAPS=3
TWS_CONFIG=OFF 1 2
UART_CONFIG=9600 OFF 0
USB_HOST=OFF
VREG_ROLE=1
set name=sierrawirelesslongname075DD3
write
reset
BlueCreation Copyright 2017
Melody Audio V6.1.8 RC3
Build: 1509623096
Ready
config
AUDIO=0 0
AUTOCONN=0
BALANCE=100 100
CLASS_1=OFF
CMD_TO=20
COD=240404
CODEC=0 OFF
CONN_TO=0
DEEP_SLEEP=OFF
DISCOVERABLE=2 0
ENABLE_BATT_IND=ON
ENABLE_CAPSENSE=OFF
ENABLE_LED=ON
HIGH_SPEED=OFF OFF
MAX_REC=2
MUSIC_META_DATA=OFF
MUSIC_OLD_AVRCP=OFF
NAME=sierrawirelesslongname075DD3
NAME_SHORT=BC75DD3
PIN=0000
SSP_CAPS=3
TWS_CONFIG=OFF 1 2
USB_HOST=OFF
VREG_ROLE=1
When I then search on my phone the full name as per the above is displayed.
