BC127: AUTOCONN problem
Dear all,
I expected that BC127 with Melody 6.1.5 will try to connect one device out off the paired devices list wenn AUTOCONN = 1 is set. But it looks like only the device which was connected last time will be autoconnected. BC127 seems not to try other devices from the list. Has somebody also observed this behaviour?
Peter
Are you just using iPhone? its touchy with iOS
But you can modify the profiles to give you pairing to up to 3 devices…
Try these commands!
SET PROFILES=2 0 3 0 2 1 2 1 0 0 1 0
SET AUTOCONN=1
SET DISCOVERABLE=1 0
I think you misunderstood my question. I dont’ want to connect to more than one device at the same time. The idea was to have for example three headsets paired with the module. When I switch on one of the headsets it should be connected automatically. But this seems to work only with the last one connected.
