BC127 battery fast charge
I would like to enable fast charge for the battery.
I have followed the design in the documentation (transistor and resistor of 400mOhms).
I have set batt_config On 145 4250 1500 200 .
But I only get 200 mA of charging.
cf documentation, the resistor should rise up the current charge to 500 mA according to the equation I=0.2/R.
Where am I wrong?
thank you
The specs only state that you can get 200mA out of the unit so what are you expecting to be able to draw?
Thank you for your answer.
I made a screenshot from the datasheet showing 500mA as fast charge in the schematic.
I also find a table with current pattern but it’s from csr8670 datasheet, so maybe it’s not implemented in bc127.
But the bc127 schematic is ambigous I think.
Could you explain me what means the schematic please?
thank you
Fred,
I suspect this is a slight disconnect between the hardware and software teams where the software limits it to 200mA. Can you push this back through our commerical (so distributor) channel to get a proper answer?
Yes it should be something like that, hardware possibility but limited in software.
It’s ok, 200 mA should be enough for me.
thank you
