BC127 HD Analog Mic Settings:
Hey Matt:
We need help! We are so close to launching “The Shelf” ( www.vehroot.com ) bbut need a second pair of eyes on out license and settings:
We have 2 analog mics working and we have applied this license and these settings: ( and these settings seems to sound pretty good in the vehicle )
Can you have your GURUS look at this info for analog MICs and offer any suggestions/changes?
version
BlueCreation Copyright 2017
Melody Audio V6.1.5 HD
Build: 1496941831
Bluetooth address 20FABB0417F3
Profiles: A2DP AVRCP HFP BLE SPP PBAP MAP
Codecs: SBC APTX AAC
license
APTX=3061 416A 59D8 EA03 0000
CVC=3061 4197 54D2 7C91 8118
“We bought this cVc license ( 3061 4197 54D2 7C91 8118) from Qualcomm - Formatted for BCSW-CVC-HF-2M-Fx 2-Mic Handsfree (Flash)
This Key Licenses CVC versions BCSW-CVC-HF-4-7-1 vA00B (1Mic HF), HF-5-0-1 vA101 (2Mic HF), and HF-5-0-3 vA104 (2Mic HF)”
config
AUDIO=0 0
AUDIO_ANALOG=19 15 1 ON
AUDIO_DIGITAL=0 44100 64 184A90 OFF
AUTOCONN=1
AUTO_DATA=OFF OFF OFF
BALANCE=100 100
BATT_CONFIG=OFF 145 4250 1500 150
BLE_CONFIG=0 OFF 40 ON
BLE_CONN_PARAMS=128 12 6 40 0 400 50 400 400 61 400 400
BT_VOL_CONFIG=F F 15 1
CLASS_1=OFF
CMD_TO=20
COD=240404
CODEC=3 ON
CONN_TO=0
DEEP_SLEEP=OFF
DISCOVERABLE=1 0
ENABLE_BATT_IND=ON
ENABLE_CAPSENSE=OFF
ENABLE_LED=ON
GPIO_CONFIG=ON 0 255
HFP_CONFIG=ON ON ON ON OFF
HIGH_SPEED=OFF OFF
LOCAL_ADDR=20FABB0417F3
MAX_REC=2
MUSIC_META_DATA=OFF
MUSIC_OLD_AVRCP=OFF
NAME=Vehroot Shelf 17F3
NAME_SHORT=BC417F3
PIN=0000
PROFILES=2 0 3 0 2 1 2 1 0 0 1 0
REMOTE_ADDR=000000000000
SSP_CAPS=3
TWS_CONFIG=OFF 1 2
UART_CONFIG=9600 OFF 0
USB_HOST=OFF
VREG_ROLE=1
CVC_CFG NB 0 14
2280 0000 1A00 8000 0000 80CF 0000 0000 0000 0000 0000 0020 0000 80CF
CVC_CFG WB 0 14
2284 0000 1A00 8000 0000 80CF 0000 0000 0000 0000 0000 0020 0000 80CF
We are also testing DIGITAL Mics: but it doesn’t not seem like we can get the cVc working, Can you look at these settings and let us know if you see anything we have wrong?
Unfortunately this BC127 HD had the cVc aptX DEMO applied to it so we are not able to use the 2 MIC Hands free license from Qualcomm.
Could the DEMO cVc license be the reason cVc does not seem to work?
version
Build: 1496941831
Bluetooth address 20FABB000180
license
APTX=3465 57F8 42AE A223 4820
CVC=3465 57F8 42AE FC81 0000
config
AUDIO=1 0
AUDIO_DIGITAL=0 44100 64 184A90 OFF ( IS THIS CORRECT??? )
AUTOCONN=1
BALANCE=100 100
CLASS_1=OFF
CMD_TO=20
COD=240404
CODEC=3 ON
CONN_TO=0
DEEP_SLEEP=OFF
DISCOVERABLE=1 0
ENABLE_BATT_IND=ON
ENABLE_CAPSENSE=OFF
ENABLE_LED=ON
HIGH_SPEED=OFF OFF
LOCAL_ADDR=20FABB000180
MAX_REC=2
MUSIC_META_DATA=OFF
MUSIC_OLD_AVRCP=OFF
NAME=Vehroot Shelf 1807
NAME_SHORT=BC41827
PIN=0000
SSP_CAPS=3
TWS_CONFIG=OFF 1 2
USB_HOST=OFF
VREG_ROLE=1
( DO WE NEED THESE SETTINGS FOR DIGITAL MICS??? )
CVC_CFG NB 0 14
CVC_CFG WB 0 14
Thanks guys!!! I’m pretty sure Future does not have this info… That’s why I am submitting it directly… Let me know if you need to send responses to them or get them to submit these questions… We just need to move quick!!!
Shauno - Vehroot LLC
Matt… no reply on this?
