BC127 AVRCP only profile
Hello.
I want to use AVRCP commands only to change tracks etc. with no A2DP connection.
If I configure the module that way it does not work.
If I then enable A2DP sink in profile settings the A2DP does not connect, but the AVRCP commands then work.
Is this a bug or a feature? Can it be done?
Best regards,
Igor
Igor,
Can you post some example scripts of what you are trying to do?
