BC127 HFP microphone audio
Hi Sorry if this has been answered before, but I cannot get the microphone to work during a HF call.
I have a BC127 running Melody 6.0.46, connecting to an iPhone running 10.3.3. If I call the iPhone the ringing is heard via the BC127, I can answer the call on the BC127 and I can hear the audio from the remote phone, but the remote phone cannot hear audio from the microphone connected to the BC127.
We have checked and the signal from the microphone is present at the correct (left) input, but nothing is sent via the BC127.
I cannot find any document that says “this is what you need to configure to get a 2 way HFP call working”
Any help would be greatly appreciated.
Pete
Pete,
Couple of things,
  • Defaults should be enough to route a call through successfully.
  • I would first upgrade to the latest greatest version 6.1.5 firmware matter of good practice.
  • Make sure you are using the audio out plug on the disc kit and not the stereo out one.
  • I have just made a call to my iPhone 4 and it all connected through correctly (although I did have to route the audio to BT on the iPhone) as per the below. I have shown the config on my unit for you to reference.
version
BlueCreation Copyright 2017
Melody Audio V6.1.5
Build: 1496939390
        Bluetooth address 20FABB075DD3
        Profiles: A2DP AVRCP HFP BLE SPP PBAP MAP
        Codecs: SBC
status
STATE CONNECTED[0] CONNECTABLE[ON] DISCOVERABLE[ON] BLE[IDLE]
config
AUDIO=0 0
AUDIO_ANALOG=15 15 1 OFF
AUDIO_DIGITAL=0 44100 64 100A00 OFF
AUTOCONN=0
AUTO_DATA=OFF OFF OFF
BALANCE=100 100
BATT_CONFIG=OFF 145 4250 1500 150
BLE_CONFIG=0 OFF 40 ON
BLE_CONN_PARAMS=128 12 6 40 0 400 50 400 400 61 400 400
BT_VOL_CONFIG=A A 10 1
CLASS_1=OFF
CMD_TO=20
COD=240404
CODEC=0 OFF
CONN_TO=0
DEEP_SLEEP=OFF
DISCOVERABLE=2 0
ENABLE_BATT_IND=ON
ENABLE_CAPSENSE=OFF
ENABLE_LED=ON
GPIO_CONFIG=ON 0 255
HFP_CONFIG=OFF ON OFF OFF OFF
HIGH_SPEED=OFF OFF
LOCAL_ADDR=20FABB075DD3
MAX_REC=2
MUSIC_META_DATA=OFF
MUSIC_OLD_AVRCP=OFF
NAME=BC-075DD3
NAME_SHORT=BC75DD3
PIN=0000
PROFILES=2 0 0 2 2 1 2 1 0 0 1 0
REMOTE_ADDR=000000000000
SSP_CAPS=3
TWS_CONFIG=OFF 1 2
UART_CONFIG=9600 OFF 0
USB_HOST=OFF
VREG_ROLE=1
PAIR_PENDING
PAIR_OK CC08E0AE578E
OPEN_OK 13 HFP CC08E0AE578E
ROLE_OK CC08E0AE578E S
CALL_INCOMING HFP 13
SCO_OPEN 13
CALLER_NUMBER 13 07747008670
SCO_CLOSE 13
CALL_ACTIVE HFP 13
SCO_OPEN 13
SCO_CLOSE 13
SCO_OPEN 13
CALL_IDLE HFP 13
SCO_CLOSE 13
Hi Matt
Thanks for the response. It is good to know that there is nothing special I need to do to make this work. I will go through your settings and compare them with mine and also try upgrading to the latest version.
Fingers crossed!
Pete
