I issued a command to the BC118 module to change the baud rate to 57600.
Since then the BLE module is not connecting. Each time I try to reset the module, it returns ERR.
I tried changing baud rate back to 9600, but no change. I also tried to connect via Melody Smart app to reload firmware but the app does not see the module.
I should also mention that this module is wired to my custom board. Its not a development board for evaluation.
So if you are able to still send commands to the unit? This is implied but just want to make sure. If you do a scan either on your phone or from the BC118 do you see the other devices?
Can you send the following to the unit toget it back to a known good config and change it from there
rtr
wrt
rst
What was the command you sent to change the baud rate?
I tried the restore, write, and reset commands. But BC118 does not return either ERR or OK. I’m not seeing any reply back from the BLE module.
I used the UART=(BAUD) command to change the baud rate.
I issued
set uart=00eb
After the above I reset the terminal to 57600bps and it was communicating correcting at this baud rate.
I took it back to 9600 and tried setting it to 57600K again but did not send the WRT command before resetting it and it remained @ 9600, are you sure you are saving it and it is still not at 9600?
I suppose, I should have done a write and reset after changing the baud rate.
I added both of these commands and it worked. I then changed the baud rate back to 9600 then did a write and reset and it worked again.
I’ve run across another problem and I’m hoping have seen it before.
In testing I decided to test 2 different units which also have BC118 BLE modules.
The problem I ran across was that 1 of the newer units, only connect and allows me to configure the BLE when baud rate is at 9600. If I try to configure the module at 57600 baud rate then none of the commands (restore, write, reset) work. I always get back an error. But at 9600 it works fine. Have you run across a this problem?
