switch mode in high speed mode
After enabling high speed mode, will the “$$$$” escape sequence works in latest 6.1.5?
Since I don’t have PIO_5 connected, if I use VREGEN long to power off and off the module.
Will the module try to close currently connection gracefully? or just cut off the power?
Best,
Brett
Brett yes the unit should keep the escape sequence enabled, the high speed should not make a difference.
I also try the data mode exit in FW 6.1.5.
after the iap session is opened, and entering data mode. I cannot exit data mode with escape string
The manual has indicated this usage, I am wondering if later this will be resolved?
Brett,
I missed that note in the documentation so yes it does seem that the escape sequence is disabled for high speed mode.
