I have got BC127 Dev kit and as i have studied that it has inbuilt apple co-processor chip. But I am still unable to connect device with my apple homekit app. Is there any particular process or steps to connect BC127 Dev kit with homekit?
Please share if any videos or documents available.
Sorry but I have not understood your question clearly. But I am willing to use this dev kit with apple homekit app.
Can I use it or do I need any external hardware?
There are two development kits for the BC127, the small one and the big one, the big one has the authentication chip on board, you can buy these from the blue creations webshop (currently trying to get these available through the distribution channels).
In one of the document I read my module by default is in command mode while it has to be in data mode.
But I am trying to change its mode but things are not working out.
I think the key issue here is not data mode or command mode (this is just a mode the UART is in) it is the fact that you are not able to see the unit in your home app.I am limited in what I can test as my setup does not have an authentication chip (hence I cannot do what you are doing).
