Apparently PIO are active high by default, is it possible to set them as active low?
thank you
thank you
Fred,
Pretty sure you can’t.
Matt,
Ok, thank you for your answer.
best regards
Fred,
Try using a simple inverter on the PIO pins you want to be active low.
-josh
