WP7700 AT command set
I am trying to transition from a nimbelink product to the WP7700, running on a micro that does not support Legato or Linux. I found the AT command set for the 76xx products, but there does not seem to be anything available for the 7700.
How close is the WP7600 command set to the WP7700 command set? Even better, is there a timeline for the release of the 7700 command set?
Thanks!
Contact your FAE/distributor, there is a preliminary document out under NDA. When you say compatible it is a question of what you want to do, suggest you get hold of the document d go through it before going any further.
