Send multiple SMS simultaneously using Multiplex?
Is it possible to send multiple SMS simultaneously? Will multiplex what I am looking for? Can either the SMS or MMS be multi threaded in any way using the HL7588, or is it impossible to send more than one at a time?
I understand Sierra allows you to upload custom applications into the module, would that be necessary / possible? I just picked up the MangOH Green and dual HL7588 and would like to know if it is possible.
This problem needs a detailed technical analysis. Please contact your Technical support in SWI to provide you the solution.
Thanks & Regards,
Moderator
I think it is in the nature of the Short Message Service (SMS) that each message has only a single destination?
To send to multiple recipients you will have to
  • either: have your application send them individually
  • or: use a “Bulk SMS” service
Not the HL series - you need the WP series for that:
sierrawireless.com/products … t-modules/
Again, you need an WP series module
