I tried to send header info to a website.
AT+KHTTPHEADER=1 (\r\n)
<CONNECT
Accept : text/html (\r\n)
–EOF–Pattern–
after this I am not getting ‘OK’
What could be wrong?
AJ
<CONNECT
–EOF–Pattern–
AJ
Are you able to exit from Data mode and able to enter in command mode? If yes then are you able to execute other AT commands?
Thanks & Regards,
Rex
Rex,
I was doing some workaround to release the project.
Regarding the header, I was unable to exit from data mode to enter in command mode.
I have to power cycle the module to execute AT commands again.
I have one more question regarding the connectivity.
Is it necessary to execute CEREG? command every time when I do power up the HL module?
The module takes minimum 1 minute to 45 minutes to get +CEREG: 0,1 ( I have good signal in these locations)
Is it a normal behavior of HL modules?
AJ
Hi AJ,
can you please check the response of AT+KPATTERN command, and confirm the pattern that is being used to come out of the data mode is correct .
This is not normal behavior of HL module usually it takes less time to register on network. For information check out the AT command guide.
Thanks & Regards,
Rex
