just got the devkit tried it on all working fine i’m only interested in connecting to the 3G or 4G networks for now went through the AT command guide didn’t spot anything relevant to my needs. can anyone here give me some pointers please. basically all i want is setup network credentials and configuration and connect / disconnect from the
Generically speaking everything is done automatically i.e. the unit will choose the best network and the one it is directed to by the SIM card. You are able tp manually take control of this process using the at+cops command but only do this if you have a specific need and understand what you are doing i.e. if you manually select network X and then lose it the unit will not automatically re select another network.
