Frozen HiloNC V2 with CCLK
hi
When i use AT+CCLK after AT+CGATT=1 the module is frozen
I test it again firmware 5.01 and 8.00
AT
AT+CGMR
SAGEMCOM Hi2N,A.008.00
AT+CCLK?
+CCLK: "00/01/01,00:12:11+00"
AT+KSREP=0
AT+CMEE=1
AT+CFUN=1,1
AT+CTZU=0
AT+CTZR=0
AT&K3
AT+KCNXCFG=0,"GPRS","internet.sierrawireless.com","",""
AT+KCNXTIMER=0,40,2,55
AT+KCNXPROFILE=0
AT+KPATTERN="--EOF-Pattern--"
AT+CREG?
+CREG: 0,5
AT+CGATT=1
AT+CCLK?
The Module doesn’t respond and it’s frozen ( i must reset the module ).
Event if i try to detach the network ( AT+CGATT=0 ) before send(AT+CCLK?) i have the same problem.
It’s work with the firmware 3.0
Are you still facing the issue with the latest FW 9.0 ?
-Alex
