What exactly is the difference between LAN and WAN mode?
I’m using an RV50, and I’m having trouble getting the Ethernet port to work properly. I need the Ethernet port to talk to the internet and a server on the local network, but I can only get one of those to work. Here’s our setup:
When I set the RV50’s Ethernet port to WAN mode, it won’t talk to the Modbus server. When I set it to LAN mode, it won’t talk to the internet. What exactly is the difference between these two modes? Which one should I be using for this application?
Please contact authorized distributor in SWI for your support to provide you the solution.
you can refer to below mentioned link to get the authorized distributor details.
https://www.sierrawireless.com/distributor-page/#/
Thanks and Regards,
Moderator
It looks like you need to setup your Ethernet Router with the proper settings. Do a google search on Router on a stick. there are good videos for this.
