Hi Experts,
We have updated around 30 of our RV50 wireless modems firmware to version 4.8.1 (from 4.5.x) following the security bulletin. The modems have some issues with the COM port connection now after the update. The modems were working fine with a sensor feeding each of them some data through the COM port before the update.
Now, many of our modems just stopped forwarding data from the COM ports. Some of them still forward data, but in an intermittent fashion. One out of our 30 updated modems seems to work normally.
It’s not a COM port configuration issue. We haven’t changed the settings after the firmware update, and we found out that by toggling the hardware flow control a few times, the problem improves. We started from a “disabled” HW flow control state to a “disabled” HW flow control state for the COM port, but somehow toggling a few times that option helps the situation. So it looks like there are some bugs in the COM port part for the 4.8.1 firmware for the RV50.
These wireless modems are feeding us critical data, so before Sierra Wireless has a fix, does anyone has 4.5.x firmware for RV50 for us to flash back to? We tried looking online ourselves, and only the 4.8.1 version is available.
Thank you very much!
