I have recently deployed an RV50x in Canada operating on the Bell network and it seems the CA is flapping from Active to Inactive.
Here is the two different modem debugs:
AT!GSTATUS?
!GSTATUS:
Current Time: 57796Temperature: 31
Reset Counter: 1Mode: ONLINE
LTE band: B4 LTE bw: 15 MHz
LTE Rx chan: 2325LTE Tx chan: 20325
LTE CA state: ACTIVE LTE Scell band:B5
LTE Scell bw:5 MHz LTE Scell chan:2535
RRC state: RRC Connected
IMS reg state: No Srv
PCC RxM RSSI: -57RSRP (dBm): -77
PCC RxD RSSI: -60RSRP (dBm): -80
SCC RxM RSSI: -51RSRP (dBm): -71
SCC RxD RSSI: -49RSRP (dBm): -71
Tx Power: 15TAC: 2BD6 (11222)
RSRQ (dB): -6.8Cell ID: 01BC4A00 (29116928)
SINR (dB): 22.4
AT!GSTATUS?
!GSTATUS:
Current Time: 57833Temperature: 31
LTE CA state: INACTIVE LTE Scell band:B5
PCC RxM RSSI: -55RSRP (dBm): -77
PCC RxD RSSI: -58RSRP (dBm): -79
SCC RxM RSSI: -46RSRP (dBm): -71
SCC RxD RSSI: -45RSRP (dBm): -70
Tx Power: 9TAC: 2BD6 (11222)
SINR (dB): 22.4
Is this normal operation or is something not working quite correctly? It is just running the Generic modem firmware.
Any insight would be greatly appreciated!
Thanks!!
