Alternate Dynamic DNS
I would like to use my own Dynamic DNS server and not use eairlink.com. Is this possible with the LS300, Raven, and RV50 modems?
Is there any documentation on how to set this up in IP Manager?
Hi Atsi,
The following DNS is currently supported:
Options are:
• Disable (default)
dyndns.org
noip.org
ods.org
regfish.com
tzo.com
• IP Manager
You could use IP Manager, and configure the IP address of the server for your own. I haven’t tested it, so can’t say for sure it will work. You can test it out and post the results here.
Here is the instructions for the IP Manager setup:
https://mycusthelp.net/SIERRAWIRELESS/_cs/AnswerDetail.aspx?sSessionID=&aid=520
Thanks kindly,
Jay.
