is it possible to install a C compiler into a RV50 modem (firmware 4.8.0) and be able to run C programs on modem?
Thank you
Thank you
I would also like to know the answer to this.
Not sure if that’s possible. But, you can check out the ALEOS Application Framework which you can create applications that run inside the Gateways.
source.sierrawireless.com/resou … s_af_home/
Jay.
