Raven RV50 and IP version 6
Does the RV50 gateway support IP 6 for the cellular wan interface? I don’t intend on having ip6 on the LAN interface devices, but Verizon is moving to IP6 on its public ip’s. Can these units work with that?
Hi Josh,
The latest firmware version 4.8.0.021 now includes IPv6 gateway support.You can refer to the release documentation below for more information. https://source.sierrawireless.com/resources/airlink/software_reference_docs/release-notes/aleos-4,-d-,8,-d-,0-release-notes/
Gordie
Is this a stable/production release? I just updated one gateway and I saw something pop up before the login page came back about a developer release, but it seems to be working fine. Just wondering if I should update all my gateways?
Thank you!
Hi Josh,
Yes, this is a production build. Do you see that same message when you upgraded your other devices?
Gordie
